>Im 16 and ive been turning bowl for awile but never tried a hollow form or heavely liped figure and im looking to add a lid to it so if you have any help on fitting the lid help me out.
please post your comments good or bad there all good to me.
>picture of the holowing tool i made I made it out of some thing i found on top of my dryer so i brought it down to my shop and grinded it into a tool. hey its not the highest quality but it works
Your hollow form looks really good. The inside and outside look nicely finished and I really like the bead detail around the opening. I was told once by a turning friend of mine, who knows a lot more about design that I will probably ever know, that detail to the rims and feet can really make a piece. Great job!
When you make the lid leave it loose. On a bowl of this size you will have wood movement problems. If you turn the lid out of the same material with the grain oriented the same way the lid will move with the wood and not be as much of a problem. If you make it out of another wood they may not move at the same rate and the lid can stick if it fits too snugly.
The wood will tend to become oval so the lid will only fit one direction of it is too tight. I have a rule of thumb for lidded boxes. If it's a small box I make the lid snug enough that you can pick up the whole box by the lid and then you Pop them apart with both hands. Ideally they should feel like a precision part when opened. On larger boxes I feel that the lid should come off easily without binding on the bowl. On boxes over 6 inches this is just about a necessity due to wood movement.
>Kyle: The temptation to make your own tools is great and is not at all bad, but a couple words of caution: A bad catch with the tool you showed could break a finger or sprain a wrist. Second, Don't try to make a tool out of an old file. Files are hardened to the point they are brittle, and can splinter into several sharp pieces with a bad catch. TURN SAFE ! Bill
First, great job on these turnings -- you are off to an excellent start !
Second -- about tool design: If you look in magazines or catalogs at curved tools for hollow forms, most have the cutting tip in line with the straight part of the shaft. There can be quite a curve between the shaft and the bit, but if the cutting part is in line with the shaft, and you keep the toolrest under the straight part of the shaft, the tool will feel like it is straight, even if it is bent. In other words, you can cut (scrape) the wood away with a curved tool, while eliminating the torque (twisting forces) on your arms. If a curved tool is shaped like a question mark, keep the rest under the straight part, which should line up with the cutting tip. You'll also want to keep the cutting tipangled down a little bit, but still cutting at or above center -- NEVER below center on the inside.
I hope that makes sense, but what Bill is probably getting at is that you can get hurt using curved tools if it isn't done right. I really messed up my right elbow when I started to turn hollow forms because I was resisting the torque of the tool with the horsepower of my forearm strength. Eventually I put enough strain on the tendons that I got tendonitis, or tennis elbow, and had a hard time lifting a quart of milk, or turning a doorknob. Once I learned how to use the tools correctly, my arm recovered.
The tool you show will work, but could be dangerous. There's too much information to write it all here, but check out the curved tools available, and I'm sure you could make one shaped more like that. I make a lot of hollow forms, and would be happy to help you of-list; feel free to contact me directly.
