John Lucas - articulated carving post ?
Mike Schwing from Md.
>John,
I believe you said a while back you were going to talk to Vic about some changes for the tool post. Mind sharing what you have in mind? After using this thing for a bit now I have one or two ideas of my own. Let me preface this by saying I LOVE THE THING. Here goes;
1. I wish the release/tightening knobs remained in the same place instead of rotating with the mechanism. Fumbling around for them beneath a large carving base is frustrating. It could be done pretty easily.
2. I'd like the bottom articulation's knob to be further away from the post, because in the lowest position, the toolpost banjo gets in the way of the knob during rotation and adjustment of the joint.
3. I made a detent in the post so that I am able to see when I am raising/extending it past the danger point where it might come out of the banjo and I could drop it/could fall. Would be nice to scribe a machined ring/warning mark about 1" from the bottom.
I really am enjoying this post, it is making things possible that were not before.
Re: John Lucas - articulated carving post ?
>Mike
What I was going to talk to Vic about was making an adaptor for the top that would hold a flat plate, possibly wood. You could use this to hold a router or rotary tool at an angle to cut some real fun details into pieces. It could be spirals or short notches etc. I thought if you could attach wood to this adaptor you could take scrap wood and cut it to the shape of the vessel. Then your rotaty tool could easily follow that shape to cut coves or whatever. This can easily be done by building a flat piece to fit on the lathe but I thought it would be interesting to be able to tilt the wooden guide to give you more options.
Your ideas sound great. I would send them to him. It seems like he's always trying to find a way to improve or change his pieces.
Question about post
Bernie
>Mike I turn large platters 20" plus
Ihave been doing soom carving around the rim
would this handle that size and keep it in place?
Thanks,
Bernie
Question about post
Bernie
Thanks,
Bernie
Re: John Lucas - articulated carving post ? *LINK*
Lee Weed
>Mike,
I'm using the one from Trent Bosch, it works great. Trent sells them from his website also.
Lee
Carving stand
Re: Question about post
>Bernie, it would. You simply attach your work to the post with your chuck or faceplate, and then adjust it up/down/back/foward/rotate and spin as required. I really like it. The one mentioned below by Trent Bosch looks identical in function, different in form. try www.bestwoodtools.com for the one John and I have. Nice folks.
Lee Weed
>Mike,
There is one lever that works for both the up and down and rotation of the stand and the lever stays in the same spot.
Lee
>Berni
I haven't carved on anything that big yet. The only problem I've experienced is the chuck coming unscrewed from the post. I simply carve from right to left as much as possible and that tightens the chuck instead of loosening it. My new chuck has a setscrew for reverse turning but I haven't used that for carving yet.
Ding!
>That is exactly what I've done to alleviate that problem John - use the set screw on the chuck.
