4-jaw chuck
4-jaw chuck
4-jaw chuck
shel
>Is there a special method of mounting work in a 4-jaw self-centering chuck? Google search was not much help in locating article/instructions.
Re: 4-jaw chuck
Re: 4-jaw chuck
>My personal preference is to rought the piece between centers and turn a tenon on one end. Then I mount it in the jaws of the chuck. Others may have other ways.
Re: 4-jaw chuck
Re: 4-jaw chuck
MP Wall
>To add on to above, once you turn the tennon, and change to a chuck. If you still have a center point on the outboard end, bring the live center up to the center point and put a little pressure on the piece as you tighten up the jaws on the chuck. After you get it lightly tightened ease the livestock pressure a little tighten up more. Spin the work as you do this to see that it is running as true as possible. Adjust as you need.
MP Wall
Re: 4-jaw chuck
Re: 4-jaw chuck
EagleS.C.
>If this is about a 4 jaw indepentant chuck are the nuts on the back side of the chuck supposed to be "socked" up tight?
I have a 4 jaw chuck from Grizzly.
Each jaw is adjusted indepentdantly and the are 4 hex nuts on the reverse side.
It would seem they need to be loose for adjustment ,but their tightening would "pull" the base of the piece tightly agains the base of the chuck.
Is this the correct procedeure?
Re: 4-jaw chuck
Re: Chuck help is a click away.
Al Crandall --NE of Indy--
>Nearly everything you need to know concerning chucks is located on the Oneway Manufactruing web site. It contains useful information regardless of the brand of chuck you have. Check out www.oneway.on.ca/instructions.htm and click on the oneway and Talon link on the left side of the page. When it loads, pay particular attention to the information on page 15 of the instruction manual. Mounting your blank with a tenon which is too long or doesn't have the sharp inside shoulder for the end of the jaws to register on will increase the likelyhood of a lathe based launch.
Re: 4-jaw chuck
Re: Yuor independent chuck is different.
>His four jaws adjust in unison with the turning of one screw and maintain the concentricity of the centerline regardless of work size. Your four jaws work independently of one another. Your type chuck is in wide use in the metal working industry because machinists accept the fact that a dial indicator is necessary to accurately center a piece. Woodworkers won't acccept this. Your jaws are not particularly well suited for grabbing wood because they concentrate the pressure on a small area. The hex nuts on the back should be tightened enough to keep out slop but be loose enough to easily adjust the jaws in or out. No further adjustment of those nuts should be necessary.
Re: 4-jaw chuck
EagleS.C.
>Thanks Al.
