Finishing Bowls
Finishing Bowls
Finishing Bowls
>I want to make a number of bowls In the 6 to 10 inch range as give aways to promote my real business. (The job that supports my turning habit.) Can anyone suggest a quick easy finish?
I just want everything. Quick, Easy, cheap, durable, flattering to the bowl, food safe, and did I mention easy?
Re: Finishing Bowls
Re: Finishing Bowls
>Waterlox, wax. BLO, wax. Tung oil, wax. Wax. Sanding sealer, wax. Natural shoe polish. Bri wax. And many, many others.
Re: Finishing Bowls
Re: Finishing Bowls
Bart Rhoads
>Just my opinion but it you want to promote your business I wouldnt go with a quick easy finish. You are wanting to display your work quality so go with a good finish. Later you can work on a faster, easier but quality finish
Re: Finishing Bowls
Re: Finishing Bowls
sam nelson
>I agree with Bart, take your time, slow down, go for quality not quanity, it will pay off in the long run. good luck
Re: Finishing Bowls
Re: Finishing Bowls
Sean Troy
>I allmost always use walnut oil after sanding to 600. Sean
Re: Finishing Bowls
Re: Finishing Bowls
>Thanks to both of you. As I posted my message, I knew what the answer was. I am promoting a business to intermidiaries that I don't like or respect much, but it's part of the game. OTOH, I make bowls and vessels because of who I am, not who they are.
I see some of the pro's such as Raffan put a coat of oil and wax and call it finished. I have been using lacquer and Salad Bowl Finish and several coats. Sometimes I have more time in the finish than I do making the bowl. Frustrating, but thanks again for the push in the right direction.
Re: Finishing Bowls
Re: Finishing Bowls
>Thanks Sean. Does Walnut oil go on in one coat? How long does it take to dry or cure? Is it food safe? Does it provide a reasonably durable finish that will stand being handled?
I have used oil and wax before, but found that they were subject to finger prints and that any drop of water that touch them left a white spot. I'm looking for something that will stand being passed around from hand to hand and protectt eh bowl.
I have a terrible time with Salad Bowl Finish that appears to be thinned varnish. If It is thick enough to flow into a smooth surface, it runs. Any thinner and you are left with holidays and streaks.
Re: Finishing Bowls
Ric Taylor
Re: Finishing Bowls
Ric Taylor
>Barry,
Don't feel like you're the Lone Ranger. I always have more time in the finish than in the turning.
Ric
Re: Finishing Bowls
Richard Allen
Re: Finishing Bowls
Richard Allen
>I use a long oil varnish. The brand happens to be Zars Wipe ON Tung Oil Finish. Depending on the wood a single coat works great. (some woods like 2 or 3 coats). Wipe it on and 10 minutes latter wipe it off. If the bowl is still on the lathe (as in finsih the inside and part of the outside before working the foot area) then I wipe it down with a paper towel with the lathe running. The heat from this action will speed the cureing of the finish. Even so I leave the finished bowls sit for a couple of days and then buff the bowl.
On dense oily woods like cocobola this finish (and most long oil finishes that I have tried) doesn't work very well. The stuff never seams to dry.
The finish is fairly flat but provides the protection you are looking for. The paduak lidded bowl and the Jennifer platter I posted a few days ago were finished as described.
The finish effort is worth it, especialy if you are associating yourself with the turning by promoting another business. If the bowl looks bad in a few weeks then every time they see the bowl they will think less of the business you are trying to promote.
Godo Luck
Re: Finishing Bowls
Re: Finishing Bowls
Andy in Raleigh
>I got a kick out of that in a Raffan video I watched. He didn't even do oil and wax in separate steps; he just used his "nahsty rag" (as he referred to it) with some oil and wax on it on spinning pieces for a few seconds.
