Have a question? Ask Woody!
Fire Hazard
Fire Hazard
Fire Hazard
Wood Spinner
>I had a situation that we all need to be aware of. I have been doing some production roughing out and almost had a fire that is a hazard that many have. I was working and smelled smoke, thought nothing of it until it got stronger. In looking around I found that the flying curls had caught on my halogen 500 watt lamp guard and ignited from the heat. They were falling to the floor and landing in the pile of shavings and the problem was beginning. I quickly did a clean up and no fire.
If you use the halogen floods remove the wire safety grate in front.
Good turning and be safe
Bill in Casa Grande, AZ.
Re: Fire Hazard
Re: Fire Hazard
Russ Fairfield
>However, if you do remove the guard do not touch the hot glass with anything because it will either burn you or break; and never turn wet wood because the wet shaving can shatter the hot glass. Either way, you will wish that you had left the guard in place. Don't ask. I have done all three.
There should be a law against the things.
Re: Fire Hazard
Re: Fire Hazard
RevDoug
>Russ, I thought you were smarter than that, to touch a 500 watt bulb that had been on a while. Forget the fire hazard of burning shavings. You've now got to worry about the fire hazard of burning flesh.
And ooohhhh the smell. Yuckie!
Turn 'em round,
RevDoug
Re: Fire Hazard
a 150 watt bulb is available
TD
>for these and it does not get nearly as hot. I am not saying that it is cool but it is not as hot and it does throw plenty of light.
TD
Re: Fire Hazard
Re: Fire Hazard
Russ Fairfield
>Doug, it wasn't something that I did on purpose. The rest of the story is that I touched the glass while trying to move it away from my lathe control box that was melting because it was too close. There are just days that are like that.
As I said before, these light should be outlawed.
Re: Fire Hazard
Re: Fire Hazard
Wood Spinner
>I do keep them a distance from the lathe so the problem with very wet shavings is minimal. Also most of the wood I turn is almost dry. I can't believe anyone would touch one of these. Mine are wall mounted or on a tripod.
Bill
Re: Fire Hazard
Re: Fire Hazard
Pete in Holland
>Outlaw them? Don't think so. Flamable chips on a the hot surface of the fixture is operator error. No different than one gettign tangled in a spinning lathe. A lot of light with a filiment bulb results in a lot of heat. Fact of life. The halogen work lights are a broad beam system to light up a large area, and they do a nice job of that, otherwise, you need several smaller wattage bulbs to accomplish the same thing. Turning is a small target. Suggest trying a 150 watt spot light mounted further away. Less heat, less power used, less of a fire danger because of being further away from the chip source, goal of lighting up the work still met.
Re: Fire Hazard
Re: Fire Hazard
Lan Brady
>Does everyone burn out 500 watt bulbs as fast as i do? I have not acheived more than 2 hours on a bulb. Is that normal? I have burned three of them. I was careful not to touch the bulb when installing.
Thansk, Lan
Re: Fire Hazard
Re: Fire Hazard
Jennifer@Indy.USA
>Geeze Lan.....mine last litterally for a few years! Something isn't right?
