hollowing gate
DWFII
>I was thinking about picking up a hollowing gate but neither the Kelton nor the Irons seems to come with a 5/8th inch post. Is that right?
Is there a work-around?
DW
hollowing gate
DWFII
DW
Re: hollowing gate
Lyn J. Mangiameli
>The old Kelton Gate was 7/8 inch across. Kelton has recently developed a set of Nylon gates that are sized for each of their hollowers (i.e, 1/2, 5/8 and 3/4). These gates will fit in the existing post, so if you already have the old version, you can use the new gates.
I have a prototype set and think they are great. One change I think will occur from my prototype set is that the final ones will have the bottom of the gate slot set to different heights for each gate so that you will be able interchange say between a 3/4 inch tool and a 1/2 inch tool and gate and not have to change your post height to keep the tool at the 9 o'clock position.
You can make similar gates for the Iron's ( much like the original ones that came with it), for yourself out of Delrin (you can get it from ENCO), which is easy to machine with wood tools and has natural lubricity and strength which makes for perfect characteristis for gates. You need a clevis pin to fit your arm and a forstner bit of the size you want the gate, but the actual making is very easy.
Re: hollowing gate
DWFII
>Lyn,
Thank you for your reponse. It was your great series of articles that made me start looking at hollowing gates.
I think I understand what you are saying but I haven't gotten that far. My real problem is that I have a Jet 1014 and the tool rest post is 5/8th inch in diameter. I don't think either the Kelton or the Irons is made to work on a 5/8th inch tool rest post. Am I wrong?
thanks again...
DW
Re: hollowing gate
Lyn J. Mangiameli
>Ah, yes, that is a slight bit of a challange.
If you want a commercial version, you might want to contact either Woodcut directly (through their website) or Kelton through Greg Jensen (gnjensen@cox.net) their NA rep and see if you can get a custom version. It should be very easy for Ken to make up the post for you for the Woodcut version, as it just screws into the bar. It may be a little more difficult to get the Kelton version as the post is welded to the arm housing, but I doubt it would prove much of a challenge to have Kel make one up (of course then you couldn't swap it over to an eventual large lathe as easily as replacing posts).
You could also do a hybrid design where you picked up an inexpensive threaded post from BestWoodTools, or Woodcraft or Sorby (Lee Valley has them) and get a bar of rectangular steel to tap and thread as an arm. Or get the Sorby Box Scraper platform to go with their post and all you'll have to do is drill a hole at the other end. In all of these cases, you'll need to make up your own gates or sell if Kelton will sell you some individually. Perhaps not as easy to do as just purchasing one, but still very achievable if you have a drill press. There are actually a lot of options as long as you aren't in a hurry, or are willing to make some of the components.
Feel free to contact me privately if you would like help in working out the details of any of this.
Re: hollowing gate
Steve
>DW, The Kelton has a 1" post and Irons has a 3/4", 7/8", and 1" post. You might be able to order a 3/4" and then have it machined down to 5/8".
