Chuck questions?
Chuck questions?
Chuck questions?
Dan Lanicek in TX
>I've been turning a couple of months now on my Jet mini lathe and I think it's time to invest in a chuck. I'm looking for a chuck that will last me years and can use later on when I eventually buy a bigger lathe. I'll probably keep the mini lathe so I'd probably use the same chuck on both lathes.
I have no idea when or what my next lathe will be, so I'd like to keep all my options open. In other words, I think I want a chuck that uses threaded inserts. I'm assuming threaded inserts are relatively easy to switch so I can use the same chuck on both lathes even if the spindles are different. Correct?
At this point, I'm leaning towards the SuperNova2. Is this too big for a mini lathe? It's either that or a Talon at this point. Any suggestions?
Re: Chuck questions?
tek
>I don't have any experience with the Supernova2, but I have the Talon and it's a good chuck. I went from an old craftsamn lathe with a 3/4 x 16 thread to a Nova 3000 with a 1 1/4 x 8 tpi thread. It just cost me the price of a new insert. The talon inserts fit into a tapered hole in the chuck. Three machine screws go through in the back of the insert into threaded holes in the chuck body. They draw the insert into the tapered hole. It's all very solid. To remove the insert you remove the screws. Then two of them are used to push the insert out of the tapered hole the chuck. There are two threaded holes in the insert for removal. You thread the screws through them and the push against the back of the chuck body and jack the insert out of the taper. If you are going to change inserts often. I would suggest getting extra screws. It is possible to bugger the threads on the end that pushes against the chuck to remove the insert.
Peter Teubel
>Don't worry about "too big". I use a Oneway Stronghold on Jet Minis all the time. Wouldn't have it any other way. The grip is tenacious and the extra weight adds inertia to help keep the wood spinning. The Talon or the Sn2 are also good chucks, but you'll never outgrow the Stronghold.
Bill Howatt
>I tend to agree with Peter but the smaller Talon does manage to keep out of the way better particularly on bowls under 10" in diameter. I have both the Stronghold and Talon and since the Talon uses the same style jaws it grips like very well too.
You won't be disappointed with the performance of either.
Bill
Brad Vietje
Brad Vietje
>Agreed.
Have recently had a chance to use the new S-N2, and it is a very impressive chuck. It is a huge improvement over the original Supernova; I like it a lot. Have also used the Talon. Big difference in # of various jaw sets available -- SuperNova2 has many more options at this time, and tends to cost less, as well.
Safe Spinning,
Brad Vietje
Thetford, VT
