>Is there a recommended ratio of size of faceplate to size of bowl or blank about to be turned?
I have a nice three inch facepalte for my Jet 1014, but I want to glue a piece of waste onto the bottom of a, roughly, 8"x4" semi-green black locust that I have rough rounded. Problem is that the only piece of waste wood I have available is a little less than three inches and dinged off on the edge of one side.
So I'm ondering if a two inch aluminum faceplate--like CSUSA sells-- would be big enough...sturdy enough...to handle this size bowl blank?
>The 2" faceplate will likely be large enough if you don'r have any catches. Providing a good glue joint and a secure waste block to the faceplate, small catches shoudl be fine.
BUT we are talking about WASTE WOOD. Surely you can come up with a 3" piece of wood that you can waste. I generaly use poplar as wastewood. But if I don't have a piece of poplar then I will use whatever is availble. That has been mahogany, yellowheart, maple, oak, walnut... Sure I would have liked to made something nicer than a waste block. But it's just wood. Heck the stuff grows on trees!
BTW CSUSA also sells waste blocks, but buying a board of poplar for the purpose is cheaper.
>I'm pretty new to this business--having turned a number of handles for tools and some pens and some candlesticks, and one bowl...that kind of thing, mostly requiring spindle type blanks--so I don't have much in the way of scraps accumulated. What I was planning on using was 3x3 section of cherry 2x4 that was rounded due to damage on the edges of one side.
>Don't equate waste wood with scraps. Much of the waste wood I use comes from boards that are purchased with the plan of using them for glue blocks. It might seam like a waste to cut up a perfectly good board for waste wood. But if I haven't any suitable scraps (and to be honest the scraps which would be large enough for a glue block tend to be large enough to turn something nice out of) then cutting up a 4/4 board of poplar is better than loosing an inch of turning stock to screw holes.
>I'd just cut a piece off an old 2x4 for a bowl that size. Make sure you use 1-1/2 or so #12 or bigger screws, I use sheet metal screws, and it'll hold fine.
>But take care. I have had chunks of 2" X 4" yellow pine break at the grain and the projevt goes spinning across the shop. Be cerytain the 2" X 4" is tight grained without c
