Sealing ends with Candle Wax
Chris Wenger
>I am now in possession of a little over 200 lbs of candle wax (remnants from end of batch runs from local candle maker) Was intending to use it to seal ends of green wood as I build up my inventory of free turning stock. Any pros and cons regarding its use as a sealer?
Re: Sealing ends with Candle Wax
Ace Foster in Ben Lomond 95005
>It's just paraffin with a little dye and probably perfume in it. Should work fine. Just brush it on or dip the wood in it, but have it hot enough that it wets the wood. If it forms a flaky, nonadherent layer on the wood, it's not hot enough.
And the word to the wise that's superfluous, be careful.
Ace
john Lucas
>Chris
I tried using wax for a while. It was a hassle but since you've already got it go for it. I found melting it in a pot was a hassle so I just carved off a bunch of little chunks so they fell on the top of the log and then melted it with a probane torch. I tried to keep the heat as low as possible so I didn't heat the wood anymore than necessary.
Joe Herrmann
>And also remember that when you turn the piece of wood later that your floor will be slipery, so be careful not to fall.
I used to have the kids at school seal their green bowls with paste wax and we ran into the same problem. A little mineral spirits sprinkled over the slick spots usually helped cut the shine.
Joe
Mike Schwing from Md.
>I tried John's method a time or two. I don't think it was worth it. For tiny little box sized blanks it may be effective, but the time I found required to melt and apply wax evenly by dripping or heating it with a torch was excessive. Also, it won't flexible when hardened and will be subject to damage and flaking. Plus, while using a torch can be safe, it is still a torch. Using a pot of melted wax as a dip would be pretty nice, and quick drying, but it required equipment and clean up.
Anchorseal is such a great product for this I can't see the need to go through any other procedures.
DWFII
>I've been using paraffin even on big pieces. And although I finally broke down and got some anchorseal, I agree that if you have the candle wax...use it. I also agree wholeheartedly that it needs to be hot enought to really wet or penetrate the endgrain fibers. Yes, it is hard and will break off if abused, but the wax that has penetrated will not. And besides you're not gonna use the waxed blanks for basketball practice.
Heat it in a pan...one you can sacrifice to the task...till it is clear , hot liqiud and just starting to smke. At that point turn it down a tidge and use a stiff paint brush to apint it on. If the wood is still wet (from being green) the moisture will sizzle a little...you'lll just barely be able to hear it. That's a good sign the wax is penetrating.
My two cents for the kitty...
DWFII
In the High Desert of Central Oregon
Bob Persing (Skillman NJ)
>Chris,
I have used candle wax and canning wax to seal the ends of logs. My technique is to use an iron (clothes pressing thing used extensively before permanent-press:) to melt the wax into the end of the wood. I set it pretty high and use it to melt the chunks of wax and then to "set" the wax into the end of the log or stock that has just come from the bandsaw. Certainly not as quick as anchor seal and it is not portable as a torch but it is a bit safer than a torch and has the advantage of being able to get the wax to seep into the end grain as you "iron" over the surface being sealed.
BobP
>Bob
It also gives your pants that nice shiny look when you do iron them. John
Two words
Bob Hackett
>Electric skillet
A large one from down the thrift shop.Use it outside and keep the cover handy in case it catches fire.
Mainely,Bob-Remembering the days before Anchorseal.
One thing on candle wax...
BubbaBob
>...is you oughtta ask your local candlemaker that you got it from if it is pure paraffin.
Contrary to common belief, candle wax is usually NOT just paraffin. Most candlemakers add chemicals to harden and change the melting point of their candles. The three most common chemicals used are sterene (steric acid), Polyboost 130, and Polyboost 165.
You might not mind using those chemicals, but if you are like me, when you heat something to the point that it will offgas chemical fumes you want to know what chemical you are breathing. Polyboost 130 melts at 130 and fumes about 10 degrees hotter, and Polyboost 165 melts at 165 and, again, fumes at roughly 10 degrees hotter. I'm not sure the melt/fume points for stearic acid, but I think it's about 145-155.
BubbaBob
Don Orr
>I've been doing just what several others have already said. I use straight parrafin in my mother's old electric fry pan and just dip the ends in the melted wax and let it soak in for a minute or so. I get the wax in 10 lb. blocks from craft stores like Michaels when they have sales or good coupons (40 or 50% off). Seems to work great except for pieces of wood larger than the pan.Then I just use the Anchoseal.When I'm done waxing I just put the lid back on the pan and let it cool til next time. This idea even got a write up in "Woodturning" magazine a couple years ago for which the writer got a nice gift certifcate to Oneway. Not me of course. I had only been using it for a few years when I saw it in the magazine as a new idea. Oh well, maybe another time.
Good luck!
Wm Kram
>Just to add another twist. Before Anchorseal I have used wax, melted in a 3# size metal coffee can on an electric hot plate. Also found that it could be applied effectively while still hot with a paint brush. The wax tended to be somewhat brittle after cooling.
An improvement I found was to add some oil, motor oil, mineral oil or what ever to the melted wax. That made it flow better on the wood & kept it semihard when cooled. How much oil? Just a bit by trial & error, not too critical
Bill Kram
Chris Wenger
>Thanks everyone for the wealth of input. The electric fry pan does a wonderful job of controlled melt and a dipping bath for anything under 11 inches dia. Shop air venting will definitely be on the process control list when using the wax based on the input re: the out gassing aspect of the melted wax. Good Turning to all.
Bob Elliott
>Both Craft Supplies USA and Amazon Exotic Hardwoods use wax. The stuff they use smells like melted Crayola crayons. Amazon uses a rectangular shaped crock pot looking device to store and melt the wax.
