Veritas - Innovation in Tools
Jet mini switch broke
keith zimmerman, Normal IL
>The on/off switch on my Jet Mini VS just broke on me. Anyone have this experience? I took the VS control box apart and, looking at the switch, it appears to be a simple two-pole switch that is easily replaceable. Can anyone verify this?
Anyone know the part number for this switch if I wind up having to order one?
Thanks in advance.
keithz
Re: Jet mini switch broke
Al Crandall
>Hi Keith. In a class I helped with last weekend one of the Jet minis stopped working. I pushed and pulled on the two wires going into the switch and it started working again. They weren't my lathes and the guy wanted to get back to turning, so I didn't investigate any farther.
>I think the switch on mine is beyond that Al. The switch itself is loose and has a ton of play, and doesn't click when flipped.
It definitely needs replacing.
Thanks for the response.
ketihz
Part Number, etc.
>The ON/OFF switch part number for the Jet JML-1014VS lathe is JMLVS-84.
With credit card in hand, you can call Jet at 1-800-274-6848 for a replacement.
It looks to be a very common single-pole, single-throw (SPST)toggle switch, which can be obtained at any electrical supply house. Bring the old one with you, to match sizes, amperage, and terminal type.
I hope this helps.
Re: Jet mini switch broke *LINK*
EagleS.C.
>I have a JET mini and needed assistance changing the belt earlier this week.
When I was a the JET site I noticed that my Lathe had a 2 year warranty.
Since the variable speed is relatively new the switch on yours is probabaly covered.
WMH Home page
Wood Spinner
>Take it to Radio Shack and buy a new one. Should be cheap and easier than ordering.
While you have it apart consider putting a reversing Sw. in line with the motor.
Good turning and be safe.
Bill in Casa Grande
keith zimmerman, Normal, IL
>What is a "reversing Sw"?
keithz
Wood Spinner
>For a DC motor all you have to do is reverse the feed wires to the motor. Buy a three position switch and put the wires from the controller in the midle position. Then one side oneway and the other the opposit. You can buy this at Radio Shack. Get a heavy duty one.
red red black
black black red
Bill in Casa Grande, AZ.
