link belts & Reeves pulley's
Dennis Taylor
>Well after a conference call with Jet today & a belt distributor, they say that you cannot use a link belt on a reeves pulley, the v style belt is the only belt that will work properly...the v belt fits between the pulley's and that is what makes the spindle spin, a link belt or a flat belt will not have the friction fit between the pulley's and it won't drive the spindle..that is from the 2 reps on the phone..the belt rep, is someone who provides the v belts for Jet now, I think...Dennis
Re: link belts & Reeves pulley's
Re: link belts & Reeves pulley's *LINK*
Jean Michel
>Hi Dennis,
You should have told that to my cheap JET 1236 imitation lathe, it runned on the link belt for over 2 years, the same one...
Never had a problem with this setup. I'd say, try it, you'll see.
HTH,
Jean.
My little site
Earl
>Too bad I didn't know it wouldn't work, either. I had a Delta with a link belt on it for two years. I never knew it wouldn't work. When I upgraded, I sold the lathe and the current owner is using it with the same belt. Guess I better tell him it won't work. He'll think it's working just fine unless I clue him in.
Earl
>Ha that's funny. I guess I didn't know either. I ran my homemade grinder with a reeves style pulley system using a link belt. Had it that way for 2 years before I changed pulleys.
Russ Fairfield
>The only difference that I can tell is that the belt that is specified for use on a Reeves Drive is wider and thicker than that of the standard "A" or "B" profiles, and it has less elasticity. Call this wider and thicker as a "wear allowance" if you will.
Since what we are calling the "link belt" is a standard "A" or "B" profile, it will ride in a different location on the pulleys than the true Reeves belt, and the speeds will be different. Since there is no allowance for the added wear of the Reeves Drive, it will wear out faster.
There is nothing here that says it won't work.
>Russ
I'm guessing that you won't have as much power transfer with the link belt because you won't have as large an area contacting the pulley. For my application it didn't matter. John
Yup
Russ Fairfield
>Less contact area is less friction area, and that means it will slip under a lighter load.
Again, not a problem. It will work. Most of the time nobody will know the difference.
DO YOU MEAN THEY WOULD LIE!
Dennis Taylor
>That was info I got straight from the "horses Mouth", it won't work!...going to pick up a link and try it out, sure would be easier to change the belt!!!...tks..Dennis
Re: DO YOU MEAN THEY WOULD LIE!
Peter Teubel
>My guess is that the belt supplier wasn't about to recommend a part they don't make.
Re: It's the better belt
JamieDonaldson
>I have been using the red link belts on both a Delta 700 and General 160V with great satisfaction for several years.
Bruce in N.B. Canada
>I have a link belt on my General with the reeves system for a little over two years, works great doesen't seem to be any power loss either, I would't go back to the standard V belt for love nor money. Dennis those factory reps want you to buy their belt so the ones they have in stock won't blue mold. Come to think of it I called General in Quebec before I installed them on my lathe and their answer was there shouldn't be a problem.
Regards Bruce in N.B. Canada
Brad Vietje
Re: link belts: WHY ?
Brad Vietje
>So now some fella puts his neck on the block and asks: Why ? I am thoroughly unconvinced that link belts do anything other than make more money for those selling them. I retrofitted an old Delta with a link belt, (in addition to a few other non-lathe tools) and was completely underwhelmed. Instead of reducing or eliminating vibration, they seem to simply spread the few vibrations out to many smaller ones. They also add a funny noise. In some cases that may help, but I probably won't be buying another any time soon.
Safe Spinning,
Brad Vietje
Thetford, VT
Russ Fairfield
>Brad,
Have you noticed that they haven't taken over the industrial world?? In fact, I don't ever remember seeing one of them on an industrial drive, ever.
Re: And, one of the reasons is......
Russ Fairfield
>Conventional belts fail slowly and with warning. These link belts fail suddenly and without warning.
Jean Michel
>And Dennis...
If you install the link belt, you might have to remove a link in a few weeks when the belt has stretched a bit... After that it will stay the same for a long time, have fun, safely!
Jean.
>They may not have taken over in the industrial world but certainly are used by companies that manufacture equipment where any vibration that may be introduced by a V belt will be eliminated with link belt. I worked in the engine rebuilding field, our company remanufactured internal combustion engines ( gas & diesel) from five to several thousand horsepower and many of our machines came from the factory with link belts. Some belts were manufactured with real leather. Ordinary rubber V belts will sometimes take on a set if allowed to remain idle where as the link belts won't.
Regards Bruce
Brad Vietje
Re: Says the manufacturer, of course
Brad Vietje
