Face shields, and fogging.
Russ Fairfield
>Nobody asked for my opinion, but........
Fogging is the result of the air between the face and the inside of the shield becoming saturated with moisture. There are only 2 solutions. Frequent exchange of the air under the shield, or move to a drier climate. Everything else is only temporary and usually a wasted effort.
Frequent removal of the shield can provide the air exchange required. Using a box-fan to blow air across our face will help. How frequent will depend on the relative humidity of the air in the shop. Using a powered face shield can have the added advantage of providing cleaner air for us to breath.
The dry climate has several other advantages. Wood dries to a lower equilibrium moisture content and you will never again have to worry about your work cracking when it is moved to a dry climate. You will be able to use up the entire bottle of polyurethane glue before it gets hard in the bottle. Tung Oil and other oil finishes can be used for several years after the can hasw been opened. You can spray lacquer every day of the year without worrying about moisture in the airstream and blush under the surface film.
The only disadvantage is that natural spalting is almost non-exictant, and you will have to learn how to prepare and store wood to keep it from drying too fast and cracking before you can get it to the lathe.
Re: Face shields, and fogging.
Wally Dickerman at Green Valley, Az.
>I knew I had a good reason to move to Arizona!!
Wally
Dinyar Chavda
>Thanks, Russ. I had never thought of blaming the humid climate in Philadelphia for my turning screw-ups!
Jim King-Iquitos,Peru
>Each time I have posted a photo of one of my people working without goggles someone gives it to me. Here it is very difficult in 90 degree temps and 90 % plus humidity to wear goggles. To me it is more dangerous than without them when they are constantly fogged up and one is working half blind.
>Has anyone tryed turning with an infra-red heat lamp shining on your face shield to raise the temperature above the due point? Hmmm? Turning and tanning. You could cut out the head band like a stencil so that your tan would say "I turn" or "AAW Member" Might have to use a tinted face shield to get the temperature up enough to avoid fogging. Great in winter, but maybe not in summer.
I just use a snorkel so my breath is behind me instead of inside the sheild. In through the nose and out through the snorkle. Nearly drowned last time I went swimming. Had to give it up. Swimming that is. Hard to turn under water but it does keep the dust down.
Andy in Raleigh
>Paying a little more attention today, I notice that my face shield does fog in a small upside down cone shape from my nose to the bottom edge of the shield if I don't have my DustFoe on. It's not in my field of vision and the DustFoe pretty much makes it go away. Still doesn't seem like too big a deal to me and I am in NC, which can be humid (but isn't right now).
