Wolverine settings for Ellsworth Gouge
Doug Trembath
>Folks, I have been asked to evaluate the Crown David Ellsworth Signature Gouge for a group of turners, so I picked one up today. They don't exactly give them away, do they?
Having used Glaser gouges almost exclusively for a number of years, and knowing how adamant David is regarding his grind geometry, I'd like to set up my Wolverine and Vari-grind to ensure I keep it ground correctly. I remember in a past discussion someone had a system figured out for both a grinding wheel and the Tormek that allowed them to repeatably maintain the profile. If any of you can assist me with the dimensions and jig settings you use, I'd greatly appreciate it.
Some of you know that I have almost always felt that if you can turn freehand, you can sharpen freehand. I compared the grind on the new gouge to one of my Glasers, and believe it or not, with the exception of the flute geometry, I couldn't find any appreciable difference! But for the sake of the evaluation, I'd like to use the Varigrind to keep it the same.
Any help will be appreciated, and thanks in advance.
Doug Trembath
Studio in the Woods
Re: Wolverine settings for Ellsworth Gouge
Wayne D. Fladby
>You should get a copy of the DVD that Oneway has produced for their Wolverine system. In it Kevin Clay shows how to duplicate any style of bowl gouge grind using the Wolverine sharpening system and the Vari-grind attachment.
Best of all it is FREE for the asking.
Good-luck and turn safely.
David Galloway
>You can also see it at the Oneway website. Quite good.
Lyn J. Mangiameli
>Hi Doug,
You stated my same observation, with the exception of flute shape, the Glaser Grind and the Ellsworth grind are identical.
I may or may not be the person you were referring to who can move between a dry grinder and the Tormek with repeatablitly, but alas my approach won't work on your Wolverine. I primarily use the Kelton Sharpening System (the very best I've encountered) and it allows me both to easily adjust for height and allows me to easily add my own jigs (both limitations of the Wolverine). In my case, I made a bracket that fits in the Kelton mounting "eye" that allows me to use the Tormek Universal Support Bar on a dry grinder. This means I can use the same Tormek Univeral Gouge Jig on both units and have the exact same pivots between the two.
If you go to Steve Worcesters site, I has gone about it from the other direction and offers instructions on how to set up a mounting bracket on the Tormek to take a dry grinding jig.
In either case, repeatability and speed of setting up is enhanced by making up a small stop block that will allow you to alwasy set the gouge lenth in the jig (or jigs) to the same exact extension, and by making up distance blocks that allow you do repeatedly set the distance from the pivot point to the wheel (thus set exactly the same bevel angle regardless of wheel wear). I believe the Tormek site shows how to make these blocks to fit between the Universal Support bar and the Wheel. I make mine just a little different by drilling a UHMW plastic block to fit over the Universal Support Bar, trimming it with a shooting board until it fits precisely.
This all helps me, as well as using a black magic marker and turning the wheels by hand until I was sure that my two set ups were equivalent.
