THE WOODRAT IS BACK!
Powermatic Model 45 lathe
Andy Wright
>I am looking at potentially buying a used Powermatic model 45 lathe. It came out of a school shop and has a 1/2HP 110V/220V single phase motor. It has a closed base and is in good order (aside from being scratched up)
I want some opinions on a fair price for this lathe.
Re: Powermatic Model 45 lathe
George Van in WI
>Andy, I gave $300 for mine. It was perfect condition with the safety sheild, Buck tools, and the 3/4HP motor.
Andy Wright
>That seems like a great deal (and probably a better price than average)
How much would you have paid for the lathe without the tools and accessories?
Wally Dickerman at Green Valley, Az.
>I don't know what a fair price would be, but plan on replacing the motor. 1/2 HP might be okay in a school shop to keep kids from taking heavy cuts. The PM 45 lathe has a 12 inch swing and you'd have a problem turning an 11 inch bowl with that motor. It should have a minimum of 1 HP.
Wally
Sam Dean
>Hi Andy,
I have a model 45 lathe. I bought it about 10 years ago, if I remember right, for $275.00 with a 3 phase motor. I spent another $125 for a 3/4 horse single phase motor at the local farm supply store. The lathe was in great shape except the left side of the tool rest had been broken off and was lost. But.... I've been using it exactly like that ever since, turning hundreds of bowls. Definately get at least a 1 horse motor for it, the 3/4 is way under powered. I had to replace the bearings once. The inboard is an odd ball, a little on the pricey side; outboard is standard off the shelf. Couple of suggestions: Check that the bearing race (where the inboard bearing slides into the headstock) does not have excessive wear and play. Mine does, and the repair isn't easy. Check the serial numbers to get an idea of its actual age. Mine was one of the first made, so it's pushing nearly 50 years old. Also (another problem mine has), make sure that the tailstock center and the drive center align properly. Mine is off by nearly 3/16". It looks like the slides on the tailstock have been worn so much it leans to the side! The only problem this presents is that you can't steady a bowl blank that's clamped in a chuck (the live center just makes a little circle on the spinning wood). For a beginner lathe, and especially for spidles, it's a wonderful machine. Given the opportinity to do it again, I wouldn't hesitate to pay $400 or $500 for another one right now that wasn't worn out!
Good Luck!
Sam
Arch
>Andy, Most of the lathes of that time and size:
Delta, PM, Atlas, Myford etc. were designed primarily for spindle turning with small bowl turning a secondary utility. Scroll and vacuum chucks, deep fluted hss gouges, hollowing tools and the rapid advances in the state of the art have all happened since these lathes were born. I think that 0.5 hp is probably borderline for spindle work, but much too skimpy for much bowl work even below the limits of its inboard swing.
I'd be very cautious in spending much time and money to convert these lathes. IMO, adding 1+ hp would, perhaps unnecessarily, just increase the power of what inherently is a good spindle lathe and never will be a good bowl lathe. As always, it depends on what you want to turn and how much you want to spend to do it. I'd guess $400 to $500 for a good spindle lathe with limited bowl capability.
Turn to Safety, Arch
