Care of card/doc - critique please
Mike Schwing from Md.
>This will set alongside a bowl at a silent auction to go along with the high bidder as a care/use card. Comments/advice sought and welcomed.
Care of your wooden bowl
The bowl that accompanies this printout is made from the wood of a black cherry tree. This particular tree fell over in a thunderstorm in the summer of 2004 in the woods of Loch Raven Watershed in Baltimore County. The tree was cut into sections by me with a chainsaw and then later on bandsawn to round, then shaped into a bowl on a lathe.
The finish that was put on this bowl is an oil based finish that hardens as it dries. It was then buffed on high speed wheels. The finish was not intended to be used with food service, but it is considered non-toxic should use choose to use your bowl for serving salad. This piece of cherry had such nice character that I intended the bowl for display only.
The nice shine of the bowl will be immediately dulled by contact with water, but it will not harm the bowl. Once dulled, it cannot easily be returned to the shine it had when you first received it.
If you do choose to use your bowl for food service, please clean it with nothing more than a mild detergent on a sponge or dishcloth � but no scouring. Rinse with warm water and dry immediately. Do not soak and do not put the bowl in the dishwasher because it will crack. To renew a bowl that has gone dull you may try mineral or walnut oil, but it will be a short lived fix.
If you choose to use the bowl for display as intended � furniture polish, pledge, butcher�s wax, etc� all are fine for cleaning and polishing. Water based polishes will dull the finish.
Your bowl (and all wooden bowls) will warp and distort with the change of seasons. Fruit woods such as this cherry bowl will move more than other hardwoods so you may notice that the bowl is more round in one season compared to the other. There is nothing you can do to prevent this.
This bowl will darken appreciably over time. It will take on the nice dark tone of antique cherry furniture. To accelerate this, sit the bowl in the sunshine for a few hours and give it a suntan. (it works)
If you ever wish to have the bowl repaired or the finish restored, I can do so for a fee. Or if you might like additional bowls, feel free to contact me. They make great gifts. I may be reached at mschwing@hotmail.com
Mike Schwing
Re: Care of card/doc - critique please
Tom Sweeney - Coatesville, PA
>Hey Mike,
Sounds pretty good to me - but there is 1 minor typo I found. "should use choose" - should be:
should you choose. Unless you're goin for the Brooklyn or south Philly accent ;-)
"but it is considered non-toxic should use choose to use your bowl for serving salad"
My only other thought - & I'm not sure about this - is will all the mention of warpage & dulling, etc.. turn some prospective bidders off? I think it's good that they know this might happen but maybe leave that off the card you put on the table & make a seperate care card that you give only to the winner. Again, I'm not sure that I would take this info off the card, just wondering out loud.
Les Robison
>Mike, in my hunble opinion it is too wordy. Try to net it down to a section on care and another on the characteristic of the wood, etc. If you desire I can email you the similiar type brochure I put with works I sell. Let me know via email if you want it.
Les
Russ Fairfield
>Keep it Simple. Everything past the 1st paragraph is more than I want to know.
The following is the one from Mike Mahoney's site. I hope he doesn't mind our using it.
"Bowl Care:
This Bowl is a great kitchen utensil, used to serve food such as pasta, salad, popcorn, and fruit. After use, simply hand wash with warm water and mild soap, then let it air dry. Please do not soak it in water or put it into the dishwasher or the microwave. Occasionally recondition with walnut or mineral oil. With proper care, this bowl will last for generations."
Thanks Mike.
JamieDonaldson
>Way too much information! Buyers don't have time for a novella- about 1 short paragraph of material origin (for a donation situation) and another with general usage and care info is plenty. Do not provide info about potential anything-that's leading the witness!
>Thanks guys!
ChuckS
>Mike,
Keep it short & sweet. Too much info too soon can be a bad thing. Hit the high points:
Custom made by premier turner.
No tree was harmed.
Inteded for display.
Simple care instructions.
You might put a web address on the card- "See my website for more detailed care & feeding as well as...."
My .02,
ChuckS
Mark Kauder, Phenix City, AL
>Mike,
This is what I put on the back of my woodturning business cards:
Care of turned wood art: Keep out of direct sunlight, Avoid climate extremes; Avoid prolonged exposure to water, you may wipe with a damp cloth and dry immediately; Buff with a soft cloth; Avoid the use of spray furniture polishes, instead use soft paste waxes; Contact me to restore any or to rejuvenate the finish. damage (for a fee).
Contact me for commissioned work
I put a business card in each of my bowls when on display or when sold.
Mark
Ron in Drums PA
>Nice one Mark
How about one minor change
Contact me to restore and rejuvenate the finish or damage (for a small fee).
>Thanks Ron.
I hate it when my fingers do not know what my brain wants to day, and then when my brain does not check on what my fingers did.
Mark
