jet vs mini lathe
jet vs mini lathe
jet vs mini lathe
robert davis
>is there an easy way to electrically reduce rhe lowest speed now available
(500rpm) on this lathe?
rpm)
Re: jet vs mini lathe
Arch
>One q&d way is to loosen the belt tension adjust lever and use it as a belt slipping clutch. You may need to add a rubbing dowel close behind the belt to keep it from being thrown so far backwards that it tightens at the front.
Turn to Safety, Arch
Arch
>I forgot to say before suggesting a simple mechanical way, that I doubt that there is an _easy way to _electrically reduce the lowest speed of the Jet vs mini lathe while maintaining torque. I have heard that Jet kept the speed up for a cooling fan, however the motor is enclosed?
Switch to Safety,, Arch
My question
Fred in NC
>Is what is the absolute minimum SPINDLE speed in the VS with the belt at the lowest setting, and the motor all the way down?
Anybody have a tack to check this?
