Re: Jet 1014 capacity
DWFII
>Thanks to all for your advice and tips. Today, by a stroke of luck, I got a couple of hours on the lathe and tried to rough round the medium size, semi-green, black locust bowl blank (approx. 8 1/2" diameter by 5 inches high)
I started with a lathe speed of 500 as per recommendation but I found that the wood would not keep spinning at top rpm. It would slow down to a dead stop at times. i am anot sure if this was because I was using a small drive center )it did bore its way into the wood) Or if the 1/2 hp motor on the Jet mini just doesn't have the guts to turn this big a piece (which doesn't bode well for the larger blanks).
Eventually I got the blank rounded although I had to raise the speed to 850rpm and crank the tailstock down pretty tight. On Wednesday I will put a faceplate on the rough rounded blank and turn a tenon or face the bottom in preparation for a waste block.
I have two questions:
Is this loss of torque usual for the Jet?
And what speed is recommended for turning a bowl this size?
DWFII
In the High Desert of Central Oregon
Re: Re: Jet 1014 capacity
john Lucas
>Dwfll
I think the problem was the wood. Locust is really hard. Mini lathes, including the jet don't usually have very big motors. 1/2 or maybe 3/4 horse. When your on the outside diameter of a bowl like that it is pretty easy to slow a lathe down. Especially with a hard wood and possibly a dull gouge. Even in with soft wood and a sharp tool it's possible to take a large cut and slow those lathes down.
The solution is to sharpen the tool often and take lighter cuts.
