pen press plans
pen press plans
pen press plans
John
>I am getting started in pen turning and would like to know if anyone has built a pen press? If you have would you mind sharing the plans?
Thanks
John
Re: pen press plans
Re: pen press plans
Don Henthorn
>I have plans somewhere on this computer, but right now I can't fond them. If I do I'll give you a holler.
Re: pen press plans
Re: pen press plans *LINK*
MikeinCapeMay
>John,
How about this one:
Best,
Mike
Pen press
Re: pen press plans
Re: pen press plans
bill dotten
>do you have a drill press? It works fine for me.
Re: pen press plans
Re: pen press plans
Terry Quiram
>John
I use my drill press as well and don't have any trouble.
Terry
Re: pen press plans
Dimensions
>A fellow sent me these dimensions for that press:
Here are the measurements for the pen press parts:
Handle - 14"x 3/4"sq stock - roundover first 7".
Lever Blocks - 2"x 3/4" sq stock
Joiner - 4"L x 1 1/2"W x 3/4"
Notches in Joiner - 1 1/2"d x 7/8"w
Slide - 4 1/2"L x 3/4"sq stock
Stop - 1 3/4"L x 3/4" sq stock
Re: pen press plans
Drill press
Fred in NC
>A drill press will work. You need to chuck a piece of wood or plastic in it, to act as a ram. It can be turned easily, with a tenon to fit the chuck. I don't like using metal bolts for that purpose.
The main reason for not using a drill press is CONVENIENCE. When I am turning pens I leave my vise in position all the time. If you don't turn a lot of pens at a time, that should be no problem. You can always drill holes in all the blanks ahead of time, and then use the drill press as a pen press.
That said, I like vertical pen presses much better. A cheap arbor press works well, and a lot of penturners use them.
Re: pen press plans
Re: pen press plans
Stuart Johnson
>A short pipe clamp works great. I had already purchased a press from one of the supply outfits and then saw the pipe clamp or I would have saved the money on the press.
Re: pen press plans
Re: pen press plans
John
>thanks to everyone who has responded. Yes, I do have a drill press, but like the idea of having a dedicated pen press. I have a lot of scrap oak and will probably build one. any other plans are still welcome.
thanks
john
