ADVERTISE HERE - FREE TRIAL
i need skew help.. advice
pete
>i have a 1" skew.. granted its a craftsman.. and its sharp.. but i can't seem to get the hang of it..
should i just go get one of the oval skews or rounded head skews.. or am i wasting my money..
i need help...
thanks in advance
pete
Re: i need skew help.. advice
john Lucas
>Pete
MP already suggested the Alan Lacer video on the skew. I would second that. To use the skew you need to do 2 things. Stay on the lower 1/3 of the cutting edge and make sure the bevel is rubbing. To make sure your on the bevel start with the handle low so the skew is on the wood but it isn't cutting. lift the handle until it starts to cut. You may have to rotate the handle slightly to get the skew cutting on the lower 1/3 of the edge. It doesn't matter whether you have the long point down or the long point up as long as you are cutting below the center line of the edge.
Cutting beads is a little tougher. Practice using the skew to cut long flats or tapers or long gentle curves. When you've mastered this get back with us and I'll try to explain how to cut a bead. it's much easier if you see someone do it so I would check out the video's if possible.
You might also check out any local clubs to find a turner who knows how to use the skew and have them help you out. If you need help finding a club let us know where you live and we'll try to find a group near you.
Dennis Taylor
>Get the Lacer video, I had 2 skews that I never used, tried several times, but after being chases by the wood, and having my nerves rattled I put them away, got the video from my turning club and tried each step and Alan demo'd it, and low and behold, I pick up the tool now and use it, I would recommend the video and then just keep using the tool you have...I have the oval and a flat one, and I don't really see a lot of difference, just in knowing how to use it...TRY THE VIDEO, YOU WON'T REGRET IT...Dennis
RonZ
>I agree with the above information. I will add that the video will help you change your regular 1" skew into something more usable [raius grind and round edges]. If your goal is medium to small and/or detailed spindle work , I prefer the round skew chisel.
>I started turning almost forty years ago. There weren't any videos, litterally. No turning clubs and few if any books. Get hooked into these things, they are great. You can learn from some fo the best in the workd without leaving home.
It took me years to figure out that it was a good idea to "soften" or round off the corner on the skew. Really reduces the chance it will grab in a nick on the rest. Also reduces the cance the corner will nick the rest. File your rest nice and smooth, even wax it. Try the radius grind on the cutting edge.
One advantage to learning so long ago? I did not know it was the "dreaded" skew. I like it. Practice, practice, practice. Every piece is a practice piece for the next piece. Wear your face shield.
