Dang - First Bowl Now Firewood
Charlie Anderson in Southern Maryland
>I'm a newbie who has turned 1 bad pen and 1 okay pen. Last summer, Mike Schwing helped me turn a rough cherry bowl. Yesterday I began to finish it.
I has the sides down to about 3/16" but was having a hard time getting a smooth cut on the inside. Got careless with my gouge and a catch tore the edge off. I was just repositioning after finishing a cut. Maybe I have my tool rest too close to the bowl. I'll check some videos and see.
Of well, I'll try using a jam chuck and finish the bottom for some practice. I need to cut some wood so I can get more practice.
Thanks for the moral support.
Re: Dang - First Bowl Now Firewood
Tell me about it brother
Raymond Overman in SC
>Must be something in the air. I just got back in from the icy weather and my first natural edge bowl in three pieces on the ground. I had finished turning the bowl and started sanding when I noticed a transition I didn't like on the outside of the bowl. Nothing more than a little bit, but too much for what I wanted out of it.
I'm not sure why it caught like it did. I was taking really light cuts. It may have just been a little piece of the bark edge was further out than I thought. Next thing I knew it was in pieces and I was turning air.
All I can say is jump back in and remember to read and understand your safety information that comes with your power tools and don't forget the most important safety step, your safety goggles or face shield.
Mike Schwing from Md.
>Hey it happens. I KNOW you have a lot more wood out there, and don't forget, it is only wood after all. Tool rests are good to have as close to the work as you can get it, you have better tool control and the cuts are cleaner, too.
I've been praying for good luck, too. This is what I have to show for a week's work - the top of a new bug with its head cracked open to show the lack of a brain. Carved, and colored. Hard to believe the time some people must spend on their work, seeing as how long just this is taking.
tek
>All of us make firewood. Hopefully s we go along we make more good turnings and less firewood. Starting a cut is a trouble point in turning. It's easy to get a catch or cut a spiral because the cutting edge went in without the bevel supporting it. Also when repositioning the gouge it's easy to make contact with the wood by accident, when the gouge is not in the right position. If you make contact with the wood and the gouge is not on the rest you can get some spectacular catches. The tool digs in and then slams against the rest and everything goes bad. Practice and spend some more time with Mike or another good turner and you will get better. This is a hobby for most of us, let it be fun.
Robert Cox
>My first 3 are trashed.
It's been too cold to try more.
BTW, I picked up your new diamond dresser today.
Robert Cox
>Sometimes, I worry about you....
I just wish I had the talent and skill you do.
Barry Turner
>I feel your pain...........did the same thing this afternoon on my new lathe. Talk about embarassing! Now that I have a new lathe, I expect my turning to improve overnight. Doesn't happen that way.........takes practice. Lots of it. Good luck.
>Mike,
Have you not been wearing your respirator and turning on your dust collector? It seems that you may have inhaled some funky, punky stuff. Have you been turning mushrooms (not the wooden ones)? Have you been insprired by one of the more unusual artists like Munch, Escher or Dali? Seriously though, I love your bug series. It is nice that someone has the ability to stretch the boundaries of turning.
adrien
>Mike, I thought that was a fertilized egg you'd cracked open the to of !!
Chris K.
>I feel your pain charlie, even more frustrating is that you dont know what happened to learn from it. Mistakes are the best learning tools you learn many times faster from mistakes then you learn from successes.
BTW were you at the meeting last month?
Chris
Capt Skip
>Way to go Charlie
I keep the house warm last weekend with my practice peices. :)
>Which meeting? CAW? Yes
>Only problem is that we didn't put a wood burning fireplace in this house. Maybe I'll just save them for a bonfire on the beach.
