Bandsaw Blade Resharpening
Mark Kauder, Phenix City, AL
>Not long ago, I extolled the virtues of the Highland Hardware Woodslicer BS blade for resawing.
Today, I happened to read the Bandsaw Re-saw Band Review in the WC Articles and Reviews section. It too, extolled the virtues of this blade, but noted that it did not last long.
I too ran into this same problems last week. I have probably put 300 linier feet of 1"-2" thick boards through this blade, and I went to resaw a 3" thick piece of Purple heart about 48" long. I think I just burned through it (very slowly, and not very straight).
I figured it was the end of a good thing, but Saturday morning I decided to give re-sharpening it a try. First, I applied a blade cleaning solution that I use for TS blades on it to remove the melted on pitch. Then using the method suggested by Wally Dickerman, I resharpened it in about 5 minutes. Now mind you, this is a 4 TPI 80" blade, so we are only talking about 320 teeth - I would not do it on a 10 tpi blade, though you could.
Wally's method is to just touch a Dremel tool with a grinding tip on it (I happened to us an abrasive cutoff disk) to the outer tip of each tooth (the edge closest to you when the blade is mounted and cutting).
Once done, and remounted, it cut good (and straight) as new.
Thanks Wally.
Mark
P.S. Wally is another one of those guys you should not bet on being wrong (like Russ) when it comes to things related to woodturning.
Re: Bandsaw Blade Resharpening
Wally Dickerman at Green Valley, Az.
>Thanks Mark, As you say, easy to do. I've found that often the re-sharpened blade cuts better and straighter than when new.
Wally
Rusty
>depending on how careful you are you should be able to re-sharpen a few times (3) maybe as a small bit of the kerf will be ground off each time. I have extended a few blades life time this way, although i had to use the manual method with a round file, and on a 105" 3tpi, my arms were tired.
Will it work with the carbide matrix type of blade (nor pure carbide)??
John Trant (Baltimore/DC area)
>For your type of precision work, your blade will only be good for a few re-sharpenings however it will still work fine when cutting logs for bowl blanks. Even though you probably were aware of this (you did not mention this in your post), try to keep the offset of the teath the same. I will rotate the blade twice (I leave it on the saw)... once with my hand set for one angle and again for the opposite angle.
John
I may not pinch every penny but most of mine will get streched.
Mark Kauder. Phenix City, AL
>Wally,
No Thank YOU.
I read or heard somewhere that it takes a sharp blade to cut a straight line, and the Kerf is what allows you to cut curves, so the reason that home resharpened blade may cut better and straighter, might because of a reduced kerf after sharpening.
This one cut straight to begin with because of almost no kerf.
Mark
>Rusty,
This method does not touch the inside curve of the tooth, but the outside edge of the tooth. So, you do not have to use a round file/grinding bit.
I suppose with the right grinding bit, you could do carbide as well.
Mark
>Thanks for the heads up, John.
However, this blade will never work on a bowl blank, it has almost ZERO kerf - just made for fine resawing. So, it will not cut anything but a very, very long radius curve.
Mark
jared
>remove 1 for email
Hello: I am having a hard time visualizing why you grind on the top of the tooth rather than the front face of the tooth in order to sharpen it. If I sharpen a circular saw blade or a hand saw blade I take material off the front of the tooth to make it sharp. Apparently that is not how it works on a band saw blade. Am I looking at this wrong? Is there such a small amount of metal that gets worn off the tooth that taking a small pass on the top of the tooth removes enough metal to get a square and sharp edge exposed? Thanks in advance Jared
Re: Bandsaw Blade Resharpening *LINK*
Don Henthorn
>If you think about how the blade cuts you will see that the top of the band saw tooth is in the same position relative to the cut as the front of the tooth on a hand saw. I used to sharpen all my bandsaw blades with an electric chain saw sharpener and the round stones used on chain saws. I had the setup on a work bench edge where I could rest my hand(s) to maintain good control over the sharpener. I always made a sweeping motion that included the gullet and ended up in an upsweep that just followed the curve of the tooth. Unless you have hit some steel there is only a tiny bit that needs to come off to make the tip of the tooth really sharp. To me grinding on the front of the blade destroys the geometry of the tooth and will limit the number of times you can sharpen the blade. In Europe band saw blades are sharpened not thrown away. I made a special rig to hold the bandsaw blades during sharpening. I really kept the blades on my bandsaw mill sharp and could cut thin veneer if I needed it.
http://users2.ev1.net/~henthorn
>Jared,
In my crude drawing, I point to the surface that I ground to make the BS blade sharper.
Any cutter can be sharpened by grinding/polishing either or both of the two surfaces that make the cutting edge. We do it all the time on turning gouges - we could also sharpen gouges by grinding the flute, but that is more difficult (though some do use a stone to dress the flute as well).
Router bits are sharpened on the flat side, because 1) it is easier for the machines that do it, and 2) is does not dramatically change the size and shape of the cutter. TS blades are sharpened on the front because 1) it is easiter for the automated machines that do it, 2) the carbide is made so the it is thick in that direction and will take more sharpening, and 3) there are two sharp edges involved in the cutting - the top and the outside.
You can sharpen the curve on the BS tooth (harder) or the outer edge of the point with just a tap of the grinder (easier).
Just my opinion.
Mark
