RPM's
RPM's
RPM's
Mike Gonzalez
>I am new to turning, and am wonderong what RPM's are good for what kind of working. I have read that when turning square stock to round you should use a lower RPM like around 500-600? Does this sound right, and when do I need to turn up the RPM? Thanks Mike
Re: RPM's
Re: RPM's
>Mike
Turn at whatever speed is comfortable to you and the lathe. When turning an out of balance piece you should use a slow speed. Just use your best judgement. You can always go slow no matter what your turning but can get in trouble when you speed the piece up. As you gain skill and understand your lathe better you will naturally turn at faster RPM's.
Re: RPM's
Re: RPM's
Gary in Zirconia,NC
>Also, the larger the diameter and the more out of balance the piece is, the slower you should turn it. Be sure it is fastened to the lathe securly. When you turn on the lathe, always be ready to turn it off if there is too much vibration as the lathe speeds up.
Re: RPM's
Richard Allen
Re: RPM's
Richard Allen
>For sound wood that is balanced and securely mounted on the lathe the rule of thumb for max RPM is diameter times rpm shoudl be less than 9000. I have als heard that the surface speed should be under 30 MPH if you which to do the math.
I usualy start off slow and increase the speed to a comfortable speed. But my lath has a dial I can turn to adjust the speed.
If you move a belt to adjest the spped then start off slow until you become comfortable with the speed.
Always stay out of the line of fire when turning on the lathe.
Remember that the lathe can KILL you. Most power tools can mame you but the lathe can mame and kill you. You won't care what the RPMs are if you are dead.
Good Luck
Re: RPM's
Thank you
Mike Gonzalez
Re: RPM's
Re: RPM's *LINK*
Bapa
>Mike
I would suggest you check out Alan Lancer's web site. He has a nice article on speed and explains it well.
Speed is relative, your comfort level; I turn on the lower RPMs (800 to 1400) and another turner will turn the same piece at higher RPMs (1200 to 2000). How fast, what RPM?? - feel - equipment - etc, all will tell you your comfort level.
The link is to the article on speed but take the time to check out his web site... it contains a lot of information.
Have Fun
Bapa
http://alanlacer.com/articles/speed_zone.html
Re: RPM's
Thank you
Mike Gonzalez
>Wow! Great site. Tons of great information. Thanks.
