Re: dust collectors
DWFII
>Jack,
I have the Penn State unit. I like it. But I have a very small set up and run about six foot of flex hose to the lathe and nothing else.
I think it's a pretty quiet machine but "quiet" is relative. You won't be able to hear the radio when you are within six feet of the dust collector. But you probalby wouldn't be able to hear the radio standing at your lathe, either. I have and extra set of two and a half inch hose and accessories to vacuum up the floor using he DC. when I'm doing that...out at about 10 to 15 feet from the unit, it doesn't sound much louder to me than some old vacuum cleaners I remember from my youth.
It sure pulls the dust from the lathe though. Once I dropped a piece of brass tubing that I had wrapped sandpaper around. It sucked the sand paper and the tubing through the flex tube so fast and so hard I could hear the brass tube hit the inside of the filter bag.
If I had to do it all over again, however, I think I would get the version of the same machine that has the canister on top. I may yet upgrade my DC in that way.
Good luck...but don't expect to get rid of all dust. The DC may suck it away from the work area so that you don't breathe it, but some still gets through the filter bag...and settles or is airborne again. I can't, but if you can put your CD outside, that's the best solution of all.
DWFII
In the high desert of Central Oregon
