Veritas - Innovation in Tools
Pyrography machine
Pyrography machine
Pyrography machine
Ben Aragon
>I have a 60-watt soldering station that has adjustable temp. Can I make or buy a pyrography wire handle to work with the soldering station. I would like to use different wire tips. The soldering station I have is a Weller EC 2000. The hand piece has 5 pins were it plugs into the base. Can this work, I don�t have a schematic. I was looking at the Detail Master hand piece.
Ben
Re: Pyrography machine
Re: Pyrography machine *LINK*
walta100
>Your soldering station if in good shape should Ebay for 50-100 then you can buy the right tool for the job you want to do. Your unit uses a 24 volt ac hand set with electronic thermostat. It is unlikely you could convert it
Walt A
parts list
