Threading Device
Threading Device
Threading Device
Chris in KC
>I just watched a DIY episode of Dave Hout turning a threaded lidded box. He used a device that fit on to the ways of what looked to be a Jet mini. The cutter mounted in the drive spindle with a collet chuck that must have had a Morse Taper #2 and the four-jaw chuck mounted on the device which took the place of the tail stock. I'm interested in getting something like this to cut threads for boxes. Anyone know what I'm talking about or what he may have been using?
Thanks for the help,
Chris
Re: Threading Device
Jerry Whitaker
>Chris, check out: bonnieklein.com and bestwoodtools.com
They are the only two sources I know. There may be others. Get ready to spend some pretty big money.
Re: Threading Device *LINK*
Don Weygandt
>Dave Hout was using the Baxter threader.Was designed by Willard Baxter.Can be purchased from bestwood tools Have one works great
http://bestwoodtools.com
Duane C.Leach
>Hi Chris. A turner friend of mine made one of those threading devices himself.It was made out of plywood with sliding dove tail joints so that it could be adjusted in each direction. It works real well. And the best part the cost was way under the $300 the others charge.
Good luck
Duane
