oily wood finishes
oily wood finishes
oily wood finishes
Two Ton Tommy
>Several months back I finished a Eastern Red cedar hollow form with Origional Waterlox. It seemed to take forever to dry/harden. In fact, I think it still feels a little tacky. Well being the concrete learner that I am, last night because I was lazy, I put a Waterlox finish on a recently finished cocobola duck call because I had the Waterlox soaked rag in my hand after applying it to a hollow form. You got it. This morning the finish on the hollow form is dry but on the duck call it is tacky similar to the red cedar.
I have a few questions. First, what is the best finish for oily woods like cocobola and red cedar? Second, is there anything I can do to speed the drying of my mistake? Could I wash the duck call with mineral spirits or naptha? Would this thin the residual Waterlox, thus excelerate drying? Or is it just a matter of time?
Re: oily wood finishes
John Trant (Baltimore/WashDC)
>The best finish for oily woods is lacquer but if you wish to use an oil finish (as I do), just wipe your vessel well with lacquer thinner and then immediately apply the oil finish. If penetration by the oil finish is not an issue, then you can first seal the wood with shellac then apply whatever finish you want on top of the shellac.
John
linda
>"Second, is there anything I can do to speed the drying of my mistake"
What would happen if Japan Drier was used over the sticky oil? Would this speed up the drying?
What about applying something that had more drying agents (maybe Danish Wood Oil) than the Waterlox on top, would this work?
John Trant (Baltimore/DC area)
>Adding more finish (Danish oil or Waterlox) can help with the drying simply because the solvents in the new finish will partially wash away some to the resinous oils. Adding Japan driers may work but the finish will be soft. It is best to use a compatable solvent to remove the corrupted finish, resand if necessary, wipe the wood with a strong solvent (acetone, lacquer thinner, etc) and refinsh immediately.
John
