Hout Bowl Skew
Hout Bowl Skew
Hout Bowl Skew
RevDoug
>Have any of you all used one?
What are your impressions?
What pointers do you have?
Re: Hout Bowl Skew
Re: Hout Bowl Skew
Joel Hunnicutt
>I have an old sorby long and strong. I think the grind is very similar. Works great across the bottom of a bowl.
Re: Hout Bowl Skew
Re: Hout Bowl Skew
RevDoug
>Joel, I don't know that one. Is there a current pic in any of the catalogs?
Re: Hout Bowl Skew
Re: Hout Bowl Skew
Scott Greaves in Blackfoot Idaho
>Hi Doug,
I went to an all-day session with Dave Hout a while back, and we all got to try turning with the bowl skew. It does take a bit of a learning curve, but a lot of tools do. I would think of it as a specialty use item, but maybe if I did a lot of turning with it, it might be more than a specialty item once I figured it out. Not to go off course with this discussion, but I found that buying Bill Grumbine's video to be money better spent!
Scott.
Re: Hout Bowl Skew
Re: Hout Bowl Skew
Mark Kauder, Phenix City, AL
>I attended a rotation with Dave Hout at a symposium about a year ago. In the rotation, Dave explained the bowl skew and we were all allowed to try it. It works as advertised, but in my opinion, it is a "One Trick Pony", i.e. that is all that it is good for - the final cut/s on a bowl.
About that same time, I started to approach all new tool purchases with the question, "What does this tool allow me to do, that I cannot do now with a tool I already have?"
I personally think that that a fine shear scrape with a freshly sharpened bowl gouge will do just as well.
Mark
Re: Hout Bowl Skew
Keith Tompkins
Re: Hout Bowl Skew
Keith Tompkins
>I hate to admit it, but visitors to my shop are stunned by how FEW tools I own.
The best ones seem to be the ones I make myself, for some reason.
Re: Hout Bowl Skew
Thanks for the input
RevDoug
Re: Hout Bowl Skew
Re: Hout Bowl Skew
Peter Teubel
>I have both of the Hout bowl skews. It take a bit of learning to use it efficiently (doesn't everything?) and it does what it claims to do. However, I can to the same thing much faster using a back-cut with a standard bowl gouge. Personally, I put in the same catagory as the Sorby Spindle Master....it works but it doesn't do anything an "ordinary" tool can't do.
