You Vacuum chuckers?
Bud
>Ok Vacuum chuckers, the �typical Vacuum pump� that are being bought by most woodturners, seem to be in the � to 1/3 HP range pulling between 22-26 inches in vacuum. However most of you vacuum chuckers, know that volume flow is important also. Do those of you vacuum chuckers that are using, or have used, the Typical � to 1/3 HP pumps find it adequate for just about all your needs, OR at times have you wished you had a more powerful pump or are thinking of upgrading to one with more flow like a � hp for more porous woods or other reasons? Also is there any disadvantages to a larger pump, such as a sizable increase in noise? I�m going to be setting up a system soon and prefer not to find out that I want to upgrade to a larger pump right away. I am hoping for some simple honest answers, instead of; formulas of inches of pull, to diameter of piece, to size of worm holes, pertaining to cfm air, factoring in your specific altitude and such. Not that there�s anything wrong with those who like to figure that type of stuff out.
TIA and safe turning
Bud
