Re: Sanding and finishing for chatoyancy
Sam Simpson
>Hi Y'all,
Fred, trying to improve the appearance of what we see requires an understanding of what we are looking at.
To fully understand chatoyance, I always use the fresh mown grass analogy. You know, how a playing-field can appear to have different stripes of green. We know that the pattern is simply caused by the grass being turned in one direction or another. Same thing with wood grain. I like to tell folks to visualize the grain as a bunch of drinking straws, and when you look at the end of the bunch they will be different than when you look at the side. Same with wood, the end grain appears darker.
So the best way to visualize how to finish for best effect, is to imagine that you are looking at grass waving about in the bottom of a clear flowing river. The grass appears to dance and create patterns as the water washes differing current flows over it. It is most obvious in deep slow flowing pools.
In this analogy the water represents the finish. It shouldn't come as much surprise that the clearer, the cleaner the better.
One of the most important things mentioned by the other posters, is to sand everything to its very best. Sanding scratches would be analogous to tree branches littering the bottom of our mountain pool. The second is to fully wet the grain. This is probably the hardest concept to explain. To not wet the grain would be analogous to putting a sheet of glass between the water and the grass in our mountain pool. Folks often advocate using oil as the first coat when finishing figured woods. This is because it is a foolproof way of fully wetting the wood. But if you can do it with clear lacquer the results will be even cleaner. Any amount of pigment or filler or flatting agent will have a dulling effect. That would be analogous to pouring silt into the water.
For the very cleanest look I would follow Joel's methods, using only clear lacquer, no sanding sealers. And I would thin my first coat more than the others and fully soak it, even at the expense of runs that might require some later prep work.
This method is not always the best answer though. Often a project can appear naked with such harsh finishing, particularly furniture pieces. I find it to be quite often that the golden amber tones of oils and toned lacquers will improve the appearance of a project by softening the harshness of a water-white clear finish.
Regards Sam Simpson.
