First Turned Square Plate (Question) - Pics
Wayne Cease - Atlanta
>Whoops! I posted this in the wrong forum, so I'm copying it here.
Here is my first turned square plate. I got the idea for this from a message posted by Dave Smith back in December.
Dave, how do you sand these? I could sand the bottoms on the lathe. The center of the tops I could do on the lathe as well. The corners just shredded the sandpaper, which I held loose so my fingers would not touch the corners.
Do you sand them off the lathe; ROS, hand, other? After shredding the sand paper, I just did the center and then pulled it off the lathe and did it by hand. They still need some more sanding as I can see some circle marks from my turning.
These are unfinished cherry. I need to do a little more sanding, then oil and buff them.
Click on the images to see a larger version.
Wayne
