REAL MILK PAINT
Chess set finally done. PICs
Dave Smith, Longview, WA
>My daughter ordered a chess set for her husband and I started on it the second week in November. I wasn�t a very good spindle turner when I started this set. I am still not very good but I am better now than when I started.
One set is made from lilac which I got from my number 2 daughter. The wood sat for a long time before I got it. It was badly split. Lilac splits spirally and usually has more than one split in any given section. It was hard to get enough wood to complete the set. Of course I started doing the lilac set first instead of doing the more abundant English walnut.
Some of the raw lilac material I started with.
The plans came from Woodturning Online curtsey of Shopsmith. When I do another set I will redraw the patterns for better detail and make some changes. The knight was the most difficult to figure out. For some reason I had difficulty visualizing the cut sequence of the off set turning. I think I trashed 6 turning before I figured it out. There was no instruction on carving the pieces so I tried real hard to ruin the pieces as I was figuring out how to create the dentalis. A couple hints for you if you attempt to make these pieces. The scroll saw is good for make the miter for the bishops. It is not good for cutting out the cross for the king.
I enlarged the print out of the patterns until the grid squares were 1/4". That makes the king and queen base 1 �", the other court pieces are 1 3/8" and the pawns are 1 1/4" in diameter. I put steel shot in a half inch hole in the base and poured in epoxy to hold it in place. Black self stick felt was applied to the bottom of each piece. The pieces were sanded to 600 while on the lathe and finished with 2 coats of Rockler Gel Polyurethane.
Lilac royal court.
Whole lilac army.
English walnut royal court.
Whole English walnut amry.
There were beheadings, disembowelments, and the walnut queen started life as a king. The trusty skew is to blame for all the mayhem visited on the chess pieces. Obviously I was powerless to stop the tool when it had a mind to go berserk.
Comments are welcome but no calipers are allowed anywhere near the two armies.
Dave Smith
Skewing things up in Longview, WA.
Re: Chess set finally done. PICs
john Lucas
>Dave
Great job. My son plays chess and I've been thinking about building him a set. He graduates High school in 2 years that might make a good gift. Of course it will have to be designed by me and will probably be unusual.
You said you had trouble seeing the design sequence on the knight. I find that drawing out the cuts on off center turning helps. Basically you are drawing 2 on center turnings at different angles to each other. The overlaping parts then show up well. I use a light pencil for the intial drawing and then color in the areas that will be left on the final piece with a dark pencil or marker.
I would have used the dremel for the king's cross. Well actually I would probably start the cross with the scroll saw making 2 parallel cuts and then done the rest with the Dremel.
Great job!
Mike Schwing from Md.
>Very impressive!
Very Impressive!
Roger Smith
>I can see the need to followup the chess table I made for my grandson with a set. He graduates in 4 years and that is about how long it will take to learn to use the shew.
The wood of the Lilac looks similar to some Redbud that I have been using.
Great job Dave. You look like
Alan Tolchinsky
>a darn good spindle turner to me. What a gift! How drunk did the knight get when you soaked him in alcohol? :) Alan in Md.
Joel Hunnicutt
>Very Nice! I have always wante to do a set for myself and never "gotten around to it". You inspred me to do it. Thanks.
very nice!
Tony - Memphis
Sean Troy
>Well done Dave. I used to turn chess sets to go with the Custom Chess boards I made. I know how much time and effort go into the sets. They can be fun to turn, but you would have to charge a fortune to make any money on them with all the time that goes into them. I,m sure that gift will be cherished for many generations to come. Sean
Bruce in N.B. Canada
>Dave, a beautiful job I would be proud if I could create something like that. My last name is the same as yours .... hope the ability runs with the name.
Regards Bruce in Saint John, N.B. Canada
Jennifer@Indy.USA
>Dave these look fantastic! What a great job. Are you making the board too? I'm assuming you're taking orders now that you are so proficient at this?
Bravo!
Jennifer : )
Impressive as always.
Ray Johnson
Wow!
Wayne Cease - Atlanta
Jim Shaver - Oakville, Ontario
>Hi Dave,
I am simply amazed...that is incredible, wow!
Take care,
Jim
RonZ
>Excellent job Dave, you have what to be proud of.
Very nice Dave Good planning
Chank South Jersey
Your kind comments warmed the cockles of my heart.
He said "cockles"
Jack Harrison
>heh heh
Re: Get thee . . .
>to a cardiologist!!
If you've got cockles in your heart, 1) you're in need of immediate surgery, and 2) you're eating way too much seafood!
Cockles of (one's) heart; One's innermost feelings
