Holly vase, knots, pith and all
Dave Smith, Longview, WA
>I turned this vase from the trunk of a holly tree. Pith in the bottom and about 10 knots around the side. I almost turned through the side when finishing the inside. A dead limb didn�t survive the rough turning so there is a 3/16" hole about 1/3 of the way up the side.
Sides are 3/32" and less in some spots. The piece was rough turned to about 3/8" thickness then soaked in alcohol for 9 hours. Wrapped with paper and allowed to dry for several weeks. It was basically dry after 2 weeks as the piece only lost 0.15 ounces during the third week when I finished turned the top of the vase. It took a couple more weeks before I got around to turning off the tenon.
The vase is 8" tall and 3 1/8" wide at the base. The rim is 2 3/4" wide. All the knots and the pith remained in tack. Sanded to 600 on the lathe then hand sanded with the grain with 600. Finished with two coats of Rockler�s Gel Polyurethane. It weighs all of 4.35 ounces.
The missing limb looks like a black spot at the lower right.
Several knots that did not split and crack.
The pith is off set from center because I mounted the piece in the center of the trunk.
Top of the vase.
I need to get a longer hollowing tool or not make such tall vases.
Thanks for looking.
Dave Smith
Finally setup a photo booth in Longview, WA.
