ADVERTISE HERE - FREE TRIAL
jacobs chuck
jacobs chuck
jacobs chuck
Georg Waldhof
>just curious how and if anyone uses a jacobs chuck. I picked one up for pretty cheap and thought I might explore the possibilities.
thanks
Re: jacobs chuck
Re: jacobs chuck
john Lucas
>George
I use mine constantly to bore holes in projects Either for assembly purposes or to make a starter hole for hollowing. They don't work all that well to hold things for turning or buffing unless you have a draw bar attached to the Morse taper end to keep it from coming out of the lathe.
Re: jacobs chuck
Re: jacobs chuck
Bill Howatt
>Mostly for drilling holes by placing it in tailstock with appropriate arbor. Consider it a very useful piece of equipment.
I also have a stick pen arbor that requires using it. I hold it in with a threaded draw bar.
If you have to buy an arbor for your chuck make sure the end that fits in your lathe is drilled and tapped for a threaded rod. They are too hard to do afterwards.
You only need the drawbar when using in the headstock without any tailstock pressure to hold it in.
Bill
