Two in a row... YAHOOOOOO
Tom Mullane
>Here is the little cherry bowl I was working on... 7x2.75"... this is only the second bowl I have turned that stayed together...
The rim treatment is crushed malachite stone... a lot harder to work than the crushed coral was... it actually grooved the shaper I was using... tough stuff.. instead of being recessed into the rim it is slightly raised... actually looks pretty good....
The stone in the body is there to fix a really bad pitch pocket that I ended up removing with my Dremel tool....
The finish is not as good as I wanted, but the shape is nice and I am satisfied with my second bowl... Some good wax and a buffing should take care of the outside.... for some reason it came out duller than I thought it was on the lathe...
