Articulated dust hood *LINK*
JL work
>I looked at this in the Rockler catalog. It looked reasonable, especially at 25% off. Any thoughts or comments?
Universal Dust Collector
Re: Articulated dust hood *LINK*
Ezekiel Holliday
>Oh thanks! Now I'm thinking about buying one. Now how am I going to spend my Christmas bonus?
YoYoSpin
YoYoSpin
>I've had one of those in use for about six months. Hangs from the ceiling and works very well. Its sturdy and well-made...I'd recommend it.
best regards,
Ed D.
Joel Hunnicutt
>Recently got something similar from Grizzly. It works pretty well. It is much bigger than I expected. It is probably 3 1/2 ft off the wall. It does a nice job of holding the hood it the right position.
Robert Simmons, Atlanta
>I've got something similar and it works reasonably well if you are very close to the lathe. Just remember that bends in the pipe will disturb the air flow - more turns and bends = less collection efficiency.
Robert
Lee Buck
>I use one mounted to the ceiling with the hose coming up from the floor; that is the hose does not bend as the mechanism bends but bends gently from below. It works very well for me.
I Love Mine....
Jennifer@Indy.USA
>I bought mine a year or so ago and really like it. I don't have my hose attatched to it though. I'm sure that would restict easy movement of the arm? It's a great deal for 25% off. I think that's when I bought mine last year.
Jennifer
gary clarke
>If you don't want to spend so much you can make your own with a $8.00 vent from Home Depot and plywood and some rare earth magnets to hold it to your lathe. Rube Goldberg lives on :)
Re: Normal conversion is 1' of hose = 3' pipe
Al Crandall
>Because it uses all flex hose, that item has the same drag on the efficiency of the collector as 30' of straight pipe, and 30' of 4" pipe usually is considered a tough pull for a small collector. I'd try to replace as much of the flex hose as I could with rigid pipe.
EagleS.C.
>I don't know the price of the unit you are looking at but I use a 4x10x4 HVAC floor boot suspended from the ceiling.
The boot is less than $3.00.
I have used the stiffer flex hose that I normally use with my D.C. but I like good old dryer hose for this application.
It moves enough air to capture fine dust and CA fumes.
