Segmented Turning - How to make a Zig-Zag
Mark Kauder
>First off � please forgive the crummy/blurry pictures. I was working quickly in a damned cold shop.
Creating a zig-zag segmented ring.
1)Laminate the wood, sandwich style. There is some calculating involved with how high your zig-zag will be based on the height of each lamination and the angle you cut it, but that is another subject. (or buy Lloyd Johnson�s Lamination Pro � www.woodturnerpro.com). This view is of the top. You need to make the lamination slightly thicker than the thickness that you want the ring to be. I generally start about 1�� thick, and after cleaning up glue, etc with a jointer or planner, I want to end up with 1��. This demonstration was done with a �� thick lamination that I had laying around.
2) Set your miter gauge to the angle that you want, and cut one end to that angle.
3) Clamp a stop block to your fence, and set distance of the cut to be just slightly larger than you want the resulting segment to be (e.g. 15/16� is required for a 10 �� ring, so I would cut the strip 1� wide.). I also use a sacrifical fence on my miter gauge to cut down on chip out, but it is not absolutely necessary. The stop block on the fence is set so that after the strip is cut, it is not trapped between the fence and the blade. Cut your strips. Cut extra, you WILL mess up.
4) Here are the resulting parallelagrams. Re-adjust your miter gauge to 90 degrees, and set your fence/stop block and cut off the pointy ends. The results are squares or rectangles.
Safety note: For the next two operations, you will be cutting with the segment trapped between the stop block and the blade (at least with my set up). You need to maintain positive control of the segment � while keeping your fingers intact. You can do this with some sort of clamping arrangement, or as I do, with an Awl that I have bent the tip into a hook. I can hook the segment, pull it back into the fence and the stop block, and keep my hands well away from the blade. I have never had a problem with this method.
5) If you flip one of the strips right to left, you will get a zig-zag. Now, notice that I have marked the top of these strips to show which is top, and which side will be out. Lay out the whole ring worth of segments and extras and mark them.
6) Cutting the segments on a feature ring (for me) is different than normal segments. I attach a stop block on the left side of the blade. Now cut your first segment angle on one side. MAKE SURE that you cut all segments with the mark you made on them UP. If I were really using a segment this high, I would have to use my CMS, but normally my segments are no more than 1-1 �� high.
7) Now set the stop block so that the next cut will result in a segment the width that you need. Cut all segments with the mark DOWN.
8) Once all segments are done, you can assemble your ring with whatever method you use. If you worked precisely, your zig-zags will line up.
As you can see, this same basic method can be the basis for darts, diamonds, etc. Carried out with precision and imagination you can end up with something as fantastic as this piece by our own Keith Tompkins.
Hope the helps.
Mark
Re: Segmented Turning - How to make a Zig-Zag
Mark.....
Jim Shaver, Oakville Ontario
>Hi Mark,
You blow me away....wow, that is a great post, this should go into articles...!!!
Take care,
Jim
Thank you
Harvey Brooks, Victoria, BC
>Great article,thanks for taking the time to share your techniques with us.
Brad Vietje
Re: Beautiful !! Thanks !
Brad Vietje
Fred Deadrick--Livermore, CA
>Thanks Mark, a very good description of how to make a zig-zag ring! I have copied and saved the material, but as Jim said, it would make a very useful article for the archive.
Fred
Mark Kauder
>Fred,
From the looks of the stuff you are making and posting over on WOW, I need to learn from you. You certainly do not need any instruction from me.
You need to post here, the ones that you most recently posted on WOW. They were FANTASTIC.
Mark
Tug Fork Bob
>Mark
Thanks a lot for taking the time and effort in your cold shop to explain this for us. I'm sure you will inspire a good number of us to try this---I'm also sure your work is going to keep many of us humble for a looooong time!!
Bob Achenbach
>Mark Good description. thanks, I'll put that in my files. I'll bet Jim from Ontario is laughing at us calling this cold. John
Fantastic ... and thanks!!
John Trant (Baltimore/DC area)
Fantastic!
Ron in Drums PA
>Thanks Mark!
gary clarke
>very well done. I appreciate your effort and skill
kenny in Indep mo
>Very informative, now, how do I save this message?
>Thanks for the kind remarks Mark. I got off my duff and posted tonite. Your latest series of four bowls are very attractive. I also like your new web site very much. Looks like you are doing well in the sales department!
Fred
Thank you for taking the time to write that up
Jeff Gerardot, Indianapolis IN
