platter trial
platter trial
platter trial
gary clarke
>this is a copy of the platter that Mike Schwing did last spring. I used the bread board pattern in the Incra Jig book. Excuse the pic as this is just a trial.
Re: platter trial
Re: platter trial
Mike Schwing from Md.
>I like it! The Incra projects book is where I learned that pattern, too.
Nice work.
Re: platter trial
Re: platter trial
gary clarke
>Mike,thanks for your kind remarks. I got the idea from the platter you did last spring.
Re: platter trial
Re: platter trial
>Gary,
It looks to busy to me. I think that each band in too narrow. Peraps making them wider next time would make the busy look go away. Nice platter otherwise. What's it inteneded to be used for?
Todd O.
Re: platter trial
Re: platter trial
gary clarke
>Todd, the original design is for a bread board as seen in the Incra Jig book. I was just experimenting with the technique. I guess my wife will use it for a candy dish or little snacks. It is only 8 in dia and 1.5 in high. It started as 1/32 slice and each slice increased 1/32 for a total of 17 slices. It might look better with the fibionnaci(sp) series which is more typically found in nature. thanks for your coments.
