CNC Turning Lathe
CNC Turning Lathe
CNC Turning Lathe
JAG
>Is there a CNC turning lathe other than a Hapfo? If possible one that can flute as well.
Re: CNC Turning Lathe
Fred in NC
>I don't know of a CNC lathe that can cut flutes as well. I believe there are "machining centers" that could do that. Now we are talking very high dollars.
A Legacy mill can cut profiles around a workpiece and cut flutes, usually guided by a flat pattern. A CNC version of this would be a CNC VERTICAL MILL WITH 4th AXIS (keywords for a google search!). The 4th axis consists of a computer controlled rotary table mounted vertically on the mill's table, and a tailstock.
Most of these machines are retrofits.
It is my impression that for most uses, CNC is not needed. Lathe duplicators can accomplish much of this work. I would suggest you contact Beall Tool and Legacy about your requirements. If their machines can do what you need, you will save a lot of money.
The wizard of OZ *LINK*
Fred in NC
>Not quite! But this rather inexpensive jig will cut flutes and do some milling.
Actually I am very interested in CNC for reasons other than artistic turning. I have been looking at the possibilities for the last 2 years. Looks like I will be taking some classes at the local community college for CNC and CAD-CAM. And it is in my plans to retrofit a vertical mill with 3th axis.
http://www.bealltool.com/lathewiz.htm
