What is left of a dozen square plates. PIC
Dave Smith, Longview, WA
>I turned a dozen 6" square plates the weekend we got back from our trip. They are made from scrap wood laying around the shop. The ones in the photo are English walnut, ash and bigleaf maple. The bags in the background are packed with eight plates and candles. I was going to take a group picture but I tend to put things off a little longer than I should. The other plate is near the shores of the Missouri River as part of a gift from Secrete Santa.
The plates are fun to turn and easy. Right Jeniffer? I snapped a quick picture but it is no worse than when I try to get a good shot.
Thanks for looking.
Dave Smith
Turning them square in Longview, WA.
Re: What is left of a dozen square plates. PIC
Wow! questions
Wayne Cease - Atlanta
>Those look really nice. A great gift idea.
How thick are they? Is the foot a grip for an chuck (expansion)? Did you apply a finish on a spinning lathe? Or is that crazy with those square corners?
Thanks,
Wayne
Chank South Jersey
>They are very nice ::
But 12 in one day thats a bit or work But good work
Answers, some may even by right.
>Hi Wayne,
The picture was not very good and the best plates were in the bags. I could use a glue block for starting the plates but I am lazy. I used a 2 3/8" clock insert bit and drill a hole in the center of what will be the top of the plate. The hole only needs to be about an 1/8" deep for my #2 Oneway stronghold jaws to grip. The jaws will fit into this opening if all the saw dust and other gunk is cleaned out between the jaws.
I have turned about 20 so far and only screwed up 3. Very figured wood like bigleaf maple will chip out on the trailing edge of the corners very easily. Cut a recess for an expansion grip. I try to have the inside of the foot 2 1/2" for my chuck. Taper the outside of the foot up to the same depth as the recess.
Move out to the corners and start shaping the corners working from the inside out. I find it easiest to look straight down to see the profile taking shape. Light cuts are what works best for me. I only remove enough material toward the middle to allow me to shape the curve. Once I have solid wood all the way around I clean up the ears using a shear cut with a 5/8 fingernail gouge. I try to imagine a cure that I draw the gouge through concentrating on keep the pressure down on the tool rest. Once I clean up the ears I finish the bottom curve to the base of the foot.
Finish sanding the bottom with the lathe turning. I had to do a lot of sanding on the first half dozen bowls until figured out how to shear scrape the ears.
Reveres the blank. Start from the out side and slowly shape the top to conform to the bottom curve. Once there is a solid ring of wood finish the ears including sanding. As before remove just enough material on the inside to allow shaping and finishing the ears. I found a heavy scraper works very well making finish cuts on the tops of the plate, especially the ears. Finish shaping the top being careful not to expose the chuck jaws.
Remove the plate and finish sand with the grain. I applied Rockler gel polyurethane and Buffed on the Beal wheels.
I use scraps from about 3/4 to 1 inch thick. I shoot for about 1/8" thick. I also found that I prefer less pronounced up turned corners. I like something I call flat curves but I can't explain it. I thought about writing up and article with pictures but I need a secretary for any more paper work.
Dave Smith
Got the flat work blues in Longview, WA.
Kevin Gerstenecker
>Those look nice Dave, but having seen your work "live", I have come to expect that from you. Dave and I had a nice visit a while back, and he was kind enough to explain how he turns these. I have practiced on a couple of my own slabs of Cherry before I try the nice Walnut blank Dave gave me. These are neat and unusual.......very pleasing to look at. Quick little turnings like these can help ease the pain, especially after a "Boo-Boo" moment! Nice stuff as always Dave.......thanks for sharing!
Lester Gillett in Independence Mo
>Yes Dave thoes are great looking and i know as
i received one for Christmas from the secert
santa? Dave if you are are the one that sent
it thanks and will try to do somthing with the
wood you sent with it.
Lester
Guilty as charged
>Hi Lester,
I was told you were a turner so I collected some wood that I though would make nice turnings. The plate was an after thought because I figured I should at least give you a finished item. I was more impressed with the wood I sent. It is a good thing I sent the plate so you weren't disappointed. Please let me see anything you make with the wood. I think I included a piece of big leaf maple for a square plate.
Lester you need to hold onto that plate I turned because someday it will be worth just about what you paid for it.
Happy Holidays!
Dave Smith
Down to carving the details on the chess set in Longview, WA.
Most weekends are two days long
>Hi Chuck,
I turned them over a two day period. Finishing took several days because I wasn't in a hurry. I had a stack of 13 blanks. I couldn't turn just one and then walk away. One highly figured blank lost a corner but I can still turn it into a saucer. It was a lot of fun and got easier with each plate. The best thing was the figure I found in some of the rough sawn bigleaf maple. I guess there was a reason I kept all those scraps.
Happy Holidays!
Dave Smith
Hi Dave
Dominic Greco in Richboro PA
>Dave,
These look AWESOME! What a great use for flat "scraps" (although, your scraps look better than some of my good stuff!)
And I noticed they all have the Dave Smith Signature bottom detail (concentric beads)
You know, I really need to try to turn a couple of these. Trust you to get me interested in something I haven't tried out yet! :>)
See ya around,
Dominic
Word of Warning Dom!
Jennifer@Indy.USA
>Dave...the plates look as awesome here as they did at my house.....yours is sitting pretty on my display table.....as you know I purchased the forstner bit to be able to make these....and as I thought "hey piece of cake.....no sweat...I'll knock a dozen of these out in no time and they'll sell like hotcakes!" Well I soon found out that these bugars are a pain to make! first of all flying corners are no fun....and then you have to sand while they are stagnant on the lathe. I lock the spindle and sand. They are pretty time consuming, but they sure do look neat if you use nice material for them. The second one I made I went right through the bottom...Ooops....it instantly turned into a votive candle holder that sold for $15.00 :)...the one that I didn't go through.....is still sitting here in the house. Go figure.
My visions of assembly line production of these came to a halt when I found out how long they took me to make.....now Dave must have some secret formula to knock these out....but he's keeping that tucked away :) I will make more of them after the Holidays, but when I'm on a time crunch schedule....these get pushed back.
Have fun with them Dom!
Jen
Second evolution
Bob Hackett
>My brother introduced me to a form like this but more diamond shaped.He also turns his from scraps.
He calls them wine coasters and sizes them to fit an average wine bottle bottom. A coaster and 2 stoppers is always a welcome gift at things like housewarmings.
It`s nice to return to someone`s home and see your work being put to use on an everyday basis.
Mainely,Bob
Longview=Square...?
Wally Dickerman at Green Valley, Az.
>Nice work Dave....Got your Xmas shopping done early, and using scrap wood!
Wally
