Maple burl "art" bowl
Dominic Greco in Richboro PA
>Hi Everyone,
Below is a picture of a Maple Burl Bowl I finally completed last night. This is yet another item turned from the wood left by WC's own "burl fairy", Bill Grumbine. To be accurate, this is a burl from a Ambrosia Maple as evidenced by the coloration and the beetle/grub holes. And yes, it won't hold soup. So it must be "art". :>)
This wood was cut wet from the burl and roughed to shape. The roughed-out form was alcohol soaked and allowed to dry for a couple weeks. Now with a burl, I normally wouldn't be as concerned with the wood movement. The grain is so uni-directional, that wood movement is not as critical as bowls turned from "non-burl" (is that a word?) wood. But this blank featured a small burl section as well as a larger, normal grained area. So I figured that I'd be safe rather than sorry and soak it.
After it was dry enough, I turned it to final shape only to realize that a huge knot went right through the side of the bowl. I attempted to fill the void with Inlace. I say "attempted" because as I was final turning it, the chunk of inlace came loose, and with a hearty "CHUNK!" embedded itself in the ceiling above my lathe. I intend to leave it there as a reminder why I wear a full face shield while turning.
After I recovered from the shock of feeling/seeing a turquoise colored shiruken (Ninja throwing star) whiz past my face, I decided that the void shall remained unfilled. I've never turned a "artsy" bowl. Maybe this was sign to do so now.
Since this wood heavily spalted, it was somewhat punky. I sanded to 320 grit and then applied a coat of Zinsner's Bull's Eye Sealer to help mitigate this. The bowl was then power sanded to 600 grit. I continued sanding from 1500 to 12000 grit using Micro Mesh.
Once the inside was completed, I reversed the bowl using a vacuum chuck and parted off the tenon. To give the base a bit more detail, I burned a series of concentric circles.
After sanding, I applied several flood coats of Watco's Natural Danish Oil and allowed it to cure for several days.
Using a trick I learned from my recent pen making spree, while buffing I skipped the tripoli compound, and went straight to the White Diamond. I also skipped the carnuaba wax as well. Instead, I gave the bowl a coat of Renaissance Wax and then buffed it. I found that this wax resists finger prints to a greater degree than just carnuaba.
So,.....what do you think?
Maple Burl Bowl Specs:
Outer dia.: 10 1/4"
Height: 3"
Wall thickness: 3/16"
Base dia.: 2 1/2"
Sanding Method: Sanded to 12000 Grit.
Finish: Watco's Danish Oil
Final: Buffed with White Diamond, then Renaissance Wax
Thanks for viewing.
See ya around,
My ugly mug
Dominic
Re: Maple burl "art" bowl
Lan Brady
>I like the void! I cannot imagine that the inlace would add as much attention to the bowl as that void does. Great Job!
Lan
Mike Schwing from Md.
>Well Dom, I hope you'll be encouraged to make more of this type. I think this lives up to your standards perfectly well, and would like to see it in person.
Again, can't help notice that you've adopted sanding to the high grit. I'd like to think I had a part in that, it sure helps with the finishing, looks great!!!
Ron in Drums PA
>I like it!
I have a roughed out cherry burl bowl that I soaked in alcohol. The wood has a large bark inclusion that I'm trying to decide what to do with. After seeing your bowl, I think I'm going to follow what you did here.
BTW. I never use tripoli, too aggressive for me. I usually start with white polishing compound then wax with MinWax Finishing wax which is similar to Renaissance Wax. (http://minwax.com/products/specialty/finishing-wax.cfm)
Brad Vietje
Brad Vietje
>Woo Woo ! Real nice bowl, Dominic; I find that voids get a lot of attention whenever they are left unfilled.
Still trying to picture Bill Grumbine in a tu-tu with wings and a wand, though ... :)
Safe Spinning,
Brad Vietje
Thetford, VT
>Nice piece.
Very nice finish.
Do have to say that I think I'd like the hole better if that part that makes up the free rim of the second hole had gone the way of the Inlace. Strong turned form calls for strong negative space element; that little circle is "weak" in the scheme of things [in my view, naturally].
Mark
Waiting for his burls in New Jersey
Re: Forget the Tu-Tu
>I'd settle for a shot of Bill in toe-shoes "on point"
Mark
RgOTFLgMAO on a rainy nite in Jersey
Beg pardon?
Dominic Greco in Richboro, PA
>Mark,
You wrote:
"...Strong turned form calls for strong negative space element; that little circle is "weak" in the scheme of things [in my view, naturally]."
I've read over the above about three times and still not sure what you meant. Could you explain?
Dominic
If you're lucky,...
someone here will have a copy of the doctored photo that features Bill's head on the body of his daughter tu-tu clad body. Now THAT is funny!
See ya around,
Dominic
Thanks Mike
>Mike,
Thanks for the compliments!
You wrote:
"I'd like to think I had a part in that, it sure helps with the finishing,..."
Damn straight on that one Mike. I'd been using micro mesh for pens, but never thought of using it on larger items until you brought it up. It may not be applicable for every instance, but it sure worked here (if I don't say so myself).
Honestly, seeing some of your recent gallery quality work here inspired me to get off my butt and turn something "more daring". Hopefully I can get some more in before the holidays finally take their toll!
See ya around,
Dominic
Thanks everyone
Chank South Jersey
>I think it very nice.
As for the chunk in the celling. I have one in the wall for the same reason. Every time I think I dont wish to put the shild on I remember why I do.
Re: Beg pardon?
-e-
>dom:
the wood is positive-space...the empty hole is the negative-space.
if you get a chance you might find the NOTAN philosophy of design interesting. I first learned this from David Marks. There is a cool book available you might find from your library.
Re: Like this
>In my view, the negative space, while still a complex shape is a stronger single unity, rather than a large gap with a ring form held inside. Your mileage may, of course, vary widely.
Please forgive my crude photo-editing abilities.
Mark
Hmmmm,.......
>You know,....you might be on to something there... I see your point now.
I was going for the "leave the knot/void as nature intended" feel. But now I see that removing that extra piece wouldn't have been a bad idea at all. It certainly would have made sanding much easier.
Thanks for posting this re-touched picture. It explained it perfectly.
Dominic
Bill Grumbine, Kutztown PA
>Beautiful bowl again Dominic, but you have got to stop turning this stuff for a while! I haven't even gotten to my pile yet, and every time you post one of these, it reminds me of all that stuff sitting there waiting to be turned!
Great job!
Bill
Very Nice!!!!!
RevDoug
