$$$ Savings Tip
$$$ Savings Tip
$$$ Savings Tip
Mark Kauder
>Many of you that, like me, us a SuperNova or other chuck that uses a threaded insert may have the same problem that I do. Many times when I go to take the chuck off the lathe, the chuck wants to come off, leaving the insert on the spindle. The grub screw holding the insert to chuck is marginally effective at best. SO.. the best way to take the chuck off by applying a wrench to the insert, however, there is not usually enough space to get a wrench in there.
Tekna-Tool offers a wrench for just such a purpose for about $30 from Packard Woodworks. Now far be it to take money out of Tekna-Tool or Brad Packard's pocket, but there is a solution that is 1/5th the cost.
Go to Lowes or Home Depot, and in the plumbing department you will find a "Slip Nut Wrench" for about $6. It is a cheap-o adjustable wrench designed to remove the large net that attaches the drain to the underside of your sink. It is a thin version of a crecent wrench and it works great.
Mark
Re: $$$ Savings Tip
Re: $$$ Savings Tip
Stuart Johnson
>Thanks Mark. Now if I can figure out why savings tips seem to always come after I make purchases.
Re: $$$ Savings Tip
Re: $$$ Savings Tip
Ezekiel Holliday
>Thanks! I've been needing a thin wrench to fit my spindle.
Re: $$$ Savings Tip
Re: $$$ Savings Tip - correction
Mark Kauder
>I just looked, and Packard sells the Tekna-Tool Wrench now for $16.95.
So you only save $10 dollars and shipping.
Mark
Re: $$$ Savings Tip
Re: $$$ Savings Tip
rprevett
>Thanks Mark. I thought it was only me that unstuck the chuck, unscrewed it a ways, got the big pliers, unstuck the insert, then tried to unscrew both at the same time, all the time trying to hold in that spindle lock button!!! It's on my list for borg shopping.
rick
Re: $$$ Savings Tip
Steven Antonucci
Bicycle Headset wrench
steve antonucci
>Not adjustable, but perfect fit. May be a buck or two?
Steve
Re: $$$ Savings Tip
Re: Bicycle Headset wrench
Mark Kauder, Phenix City, AL
>Hmmm, good one. Don't think I ever owned one (and I was big into bikes 15 yrs ago. I still have the wheel cone wrenches. I am not sure I ever knew that the headset nuts were a standard size.
Mark
Re: $$$ Savings Tip
30 or 32mm.......
Andy Halterman: Too much drivin' today
>32 was/is far more common. As a former wrench in a shop, I still know those. Of course, that was before mtn. bikes came along and gave us a slew of new "standards".
Andy Halterman
Loves his Chris King no-thread-sets in Hendersonville, NC
Re: $$$ Savings Tip
Leo Van Der Loo
One way no wrench needed
Leo Van Der Loo
