psi turn crafter plus extension bed??
pete
>will it fit the jet mini.. for less than half the price>??? its a direct knock off..
anyone tried this?
Re: psi turn crafter plus extension bed??
Fred in NC
>I am not totally sure that it will fit. The lathe looks almost like the Jet Mini. However, the Jet weights in a 9 lbs more. It also seems to be a bit taller. If it will fit the end of the bed, might be ok even if legs are shorter, they can be put on blocks.
You will also need a can of Krylon Ivory acrylic spray paint !!!
pete
>only problem .. i have the blue jet mini... i e mailed psi... said its made in a different country.. no way to say if the specs are identical...
i'll stick with the jet
