warning about vac chuck
John F
>Well, I finally got my vacuum chuck system working and gave it a try. I turned a 9.5" plate and put it on my vacuum chuck face plate to finish off the bottom. Well it shattered....
I immediately ran down to the merchantile and bought a vacuum "T" and a small valve to regulate how much vacuum I was applying to the items.
Now it has me wondering what the formula is to figure out how much pressure I am applying...
I have the part about the surface area, pi*r,squared....now I just need the rest of it.
anyone?
John F
Re: warning about vac chuck
Richard Allen
1/2 lb per cubic inch
Richard Allen
>The vacume guage usualy reads in inches of mercury. So the force is equal to that many inches of mercury sitting on top of the chuck.
Mercury is about 1/2 pound per cubic inch
For a 5" chuck that would be about 8 pounds of force for every inch of vacume.
Andrew Hilton
>Is this just a curiosity or are you going to try to use the calculations to determine how much vac pressure you should put to a given piece so that it won't explode again?
Re: It's all about the diameter.
Al Crandall
>John, I use 1/2 lb. per square in for an idea of how much pressure I'm using. A good strong vacuum will show about 28 in. Hg which means that atmospheric pressure will force a column of mercury 28 inches vertically into a tube which has a vacuum pulled in it. Normal atmospheric pressure is approximately 14 lbs. / sq. in., so you can interpolate that you have about 1/2 lb. per sq. in. of chuck at your disposal. Volume of the chuck, which is a cubic inch measure, has no bearing on the pressure. A chuck which is 1/4" deep will have the same pressure as a chuck which is two feet deep provided that the diameters are the same. Your problem with blowing up the plate can be solved by using using a faceplate chuck which has some sort of shim in the middle of it to control how much the center of the plate can flex. The chuck I use for plates is about 7" diameter and has a 1/4" thick gasket with some washers taped near the center. The plate bottoms out on the washers about the same time that the gasket reaches full compression.
Greg in Oshkosh
>Total vacuum is 30" of mercury. So if atmospheric pressure is 15#/in2 Then pulling 15inHg is 7.5# per in2. times the number of square inches.
For a 10"diameter vacuum chuck that's 5*5*3.14159 or 78 in2. With a 20 in of HG vacuum that's 20/30*15 or 10#/inch or the total is 78*10=780 pounds of force.
John F
>Its so I dont explode any more pieces. But it is also curiosity. I wont be doing calculations on every piece I work with, but it would be nice to have worked out a few numbers so I can work without having this over my head. Imagine a 9.5" plate spinning at around 1200 rpm shattering and tossing pieces at you. luckily I was at the end of the lathe when it happened, but I will be replacing the tarp over my work area as it now has about 20 small holes in it, not to mention that I now have several small dents in my car.
John F
>Thank you very much, exactly what I was looking for. Now I will be able to gestimate what I should be looking for.
thanks to all who responded.
John F
Jim Pugh, Ohio
>John, now that you have a bleeder valve in your system, have it fully open when you position the piece on your vacuum chuck and start closing it gradually. Hopefully you also have a vacuum gage to watch. Anyway, when the bottom of your platter/turning starts to flex you need to stop and check your gage. I typically work with a vacuum of 10" of Hg or less and have found out that a person can carefully finish the foot with < 5" (on the gage). I also like the suggestion of some support in the middle of a flat plate vacuum chuck.
Leo Van Der Loo
how much pressure on it ?
Leo Van Der Loo
>John, I use rough numbers to get some idea of the weight thats put on by the air pressure, on a turning.
30" mercury, full vacuum
15 psi = full air pressure
circle area 3/4 of DiaXDia
Here we go, Vacuum pretty good at 20"merc and Platter 10"Dia
Vacuum 2/3 of 30 or 2/3 of 15psi =10psi
Platter area 10X10=100, 3/4 of 100=75
10X75=7500 pounds pushing on that platter, wow
I think if I stood on it, it would not move.
Usually I will push or pull on it, that gives me enough of a idee how tight it sits, and that's almost always less than 10" merc.
I just did the foot and the sanding on a 16.5" white birch crotch platter, and that sat well outside my vacuum chuck, but at 10" it didn't move or implode.
Have fun and take care
Leo V
Doug Trembath
>I think it's all about the diameter of the vac chuck, myself. Think about how much area was used to hold the piece during turning, be it chuck or faceplate. I use no more than 4" diameter chuck for up to 24" platters, wall hangings, and bowls, and have never had anything come off of it, except one bowl which was of substandard wood. Gave me a black eye. Many times I turn these items thin, and you can't expect them to withstand the forces created when you have that much area to develop vacuum on.
Trying to hold the platter by the rim will make the bottom flex, and make turning the bottom to finished depth difficult as well. All the calculations aside, simply reduce the diameter of the vacuum chuck, which will reduce the area under vacuum, and consequently induce significantly less stress to the piece.
I'm glad you added the relief valve, it is essential, IMHO, as it allows us to regulate the vacuum and related stress to a workable level, and also recommend a dump valve which improves the ability to shift a piece quickly if needed without altering the vacuum adjustment.
Sounds like you're on the way!
By the way, if it had been my '75 Corvette that was subjected to the flying shards, I'd have had to sit down and cry. Glad I finally built my studio after all these years, and got out of the garage.
Doug Trembath
Studio in the Woods
Re: warning about vac chuck *LINK*
Andrew Hilton
>Oh, ok. I don't have to imagine what you're talking about. I've done it myself plenty of times with vacuum chucking setups. It's just going to happen from time to time. Well, unless you're doing really thick stuff from very stable pieces of wood, that is.
Unfortunately, there's just no way to accurately determine how much force a piece of wood, much less a turned form, is going to be able to handle without extremely considerable calculations being done. Far too many variables working here. Anywhere from the simple (and known) strengths of wood species up through diameters / thicknesses of wood and volumes of suction and into the really complex stuff such as how much that wood is compromised by the design of the turned form, degradation of the wood strength due to spalting, figure, grain direction and so on. This doesn't even address the very real issues of how much force you're putting on that piece of wood as you cut (scraping/cutting/slicing) or how thin you do cut into the bottom or even the porousity of the wood while it's on that vac. system.
Just way too much to consider to give you anything realistic in terms of "use X amount of vac pressure for y type of form and z diameter of piece". At least in my opinion and experience with these vacuum chucking systems.
What I do and what I teach with these chucks is this...
By the way, the valves so that you can adjust the vacuum level is fantastic and can be seen on the included link below. Do try to get one that isn't a "fast opener" so that you can control the pressure better/finer.
Basically, you put your piece (bowl for example) onto your faceplate and turn the vac. on with the pressure regulator valve open fully. Slowly shut the valve until you have just enough pressure to hold the bowl on the chuck but still be able to move it a bit by hand.
BY HAND, spin the lathe and adjust the bowl on the chuck so that it's in the position (usually centered) you want. Once there, slowly close that valve (vac pressure going up) until you can't pull or shift the bowl out of position at all.
If the piece is fairly thin already, go up an additional 2-3 mm Hg. Otherwise, try 5-7 mm Hg.
Again, spin the lathe by hand. If no problems, spin up the lathe under power with yourself out of the way. Stop the lathe and check to see if your piece has shifted. If so, go up a couple of mm Hg. If not, you should be ready to go.
Take light, shearing scrapes or cuts. It's all too easy to go too thin on these and cause a blow-out (literally). Use your tailstock if need be. It's usually there closeby so use it.
For extended vac. chucking sessions, keep an eye on that gauge. You may loose or even gain pressure as you're working for whatever reason. Keep checking to see if things are shifting or appearing to cave in. Usually, things aren't going to cave in much before they just explode instead.
Oh, yes, I highly recommend a battery backup for vacuum chucking systems. It's terrible when the electricity goes out or just wavers for a split second and you have a flying turning all over the place. The battery backup doesn't have to do it's thing for long. Just 5 minutes is enough, usually, to let you shut things down once you notice there's a problem.
Vacuum system & Chuck
