Keeping the "Studio" clean
Gil
>How does everyone go about keeping their shop clean? I turn and do all my wood working in the basement. Unfortunately it's not a walk out basement. I do have a bulkhead which makes removal of waste alright but still a pain. Most of my shavings leave the shop in 55 gallon contractor bags and get dumped into a giant compost heap. Does anyone have an interesting way to remove the tons and tons of sawdust created by a lathe? I'm thinking a coring system will be my next investment.
-Gil
Re: Keeping the "Studio" clean
LOML on a front end loader ;>)
Phil Joines Krum, Texas
RonZ
>Shop.....clean.... you gotta be kidding right?
Re: Keeping the sometime "Studio"mostly shop clean
MikeinCapeMay
>I've had a 2 hp Delta dust collector sitting in the corner of my shop for nearly one year. Shortly after buying it (scratch and dent from one of the online outfits) I began installing drops from most of my machinery. The past two days finally found the time (and motivation) to put in a drop for the lathe and to make the connections. I'm very fortunate that my shop is in a separate building and sits on a crawl space. I ran the pipe beneath the floor and it's up and running. It will and does collect everything from the tablesaw, joiner, planer, cmpd miter saw, bandsaw, belt/disc and BOSS sanders. I've yet to make a decision about the drill press. As for the lathe, it will suck darn near everything off of a turning (at least that which I experimented with) except for the heaviest shavings. However the best feature here is it's ability to remove the finer shavings and just about all of the dust, a blessing for my lungs and all horizontal, vertical and inclined surfaces, all of which are dust magnets. That which isn't removed can be push-broomed into a floor sweep that I installed. Finally, everything that's somehow missed and left behind will travel via shovel, as I've always done, into my 36 gallon barrel and then carried to the composter (including the walnut). I have an old air cleaner hanging from the ceiling, manufactured by Total Shop which I inherited from my Dad. I'll finally be able to tell if it actually works. In the past, what with all of the airborne dust, all it really accomplished was to clog it's filters, so while it obviously worked, I've no idea how well. Anyway, nothing unique or interesting, just a dust collection system, pushbroom and shovel, shop vac, and composter.Oh yeah, in the summer I used a box fan, recovered from someone's curbside trash, after installing a new switch I placed it strategically behind me blowing some of the dust generated by the lathe out of the open doors.
Contain the shavings
Dominic Greco in Richboro PA
Gil,
In regards to the lathe, the most I've found that I can do is contain the shavings. I accomplish this by enclosing my turning area, floor to ceiling, on three sides with sheets of plastic (or old shower curtains). When shavings fly off the lathe, they impact the plastic and fall to the floor. After that, I just pick them up with a large dust pan and broom and dump them in a trash can. The small stuff gets sucked up with a shop vac.
If I ever get the motivation, I plan on installing my long delayed 3HP cyclone and DC system. Hopefully, this will help to keep the rest of the machine as dust free as possible.
As far as getting rid of the accumulated sawdust, I empty my shop built trashcan cyclone and 1 HP DC right into a trashcan and carry it to the curb. Unfortunately, the trash guys won't take it on "yard waste day". I've been informed that this is "construction waste".
I like Bill Grumbine's "John Deer Dust Collector". If you want a chuckle, just ask him about that! :>)
See ya around,
Dominic
Dick Hines
Re: Contain the shavings
Dick Hines
>I don't try to contain the shavings. When the pile gets so high that I can't kick anymore on I bag them. When I get 3-4 bags I take them to a potter I know and she uses them to fire her pots.
As far as the dust I catch all I can with 2 dust collectors. I can't seem to catch it all though. I saw a mouse trying to mate with one of the duset bunnies in the shop the other day.
Bill Grumbine, Kutztown PA
>Hi Gil
This is how we do it around here! In the picture, taken way back in 2000, are our own Dave Smith and my oldest daughter Greta, doing homage to that famous artwork American Gothic.
If (when) I have lots of chunks to take to the firewood pile, I either make more trips, or like Phil, employ the front end loader.
Bill
Scott Thorburn
>I also have my workshop in my basement and keeping is somewhat clean is a sore point with SHMBO. I used to vacuum up and then bag the shavings and carry them up stairs and outside. This summer I made a 2hp dust collector / cyclone that fit the top of my garbage cans. I put the dust collector outside and plumb it in the window to my lathe. I now vacuum the shavings out from under my lathe directly to the trash can outside. I also use curtains to contain shavings around the lathe.
Thanks for the memories.
Dave Smith, Longview, WA
>Hi Bill,
At the time I thought it was a good idea to pose for that picture. I am having seconds thoughts now.
Dave Smith
My shop clean up person is me in Longview, WA.
Jay Dunham
>Can you describe how you terminated your dc system near the lathe? I've got one of those clear plastic jobs behind the lathe connected to my dc, but most shavings come off the front of the piece and aren't sucked it. It does a good job on sanding dust, though.
Jerry Whitaker
>I have a 1 Hp jet dust collector which I use. However it is nearly impossible to get it all. Since my shop is small and has a wider southeast door and a narrower northeast door catecornered (sp?) from each other, I periodically hang a box fan in the top of the smaller one and plug the bottom of the door with a piece of plywood. Then I turn it on, get the electric leaf blower and stir up all the dust which collects on both vertical and horizontal surfaces. The box fan then blows it out into the atmosphere.
MikeinCapeMay
>Hi Jay,
Probably the same as you. My pipe comes up through the floor and terminates in one of those plastic hoods "behind" the spindle of the headstock. I've only turned a few stoppers and roughed one bowl using it and while much of the shavings and pretty much all of the dust are "sucked up" the larger stuff is not. I'm pretty sure when I get the time and start roughing bowls I'll find that most of the bigger stuff hits the floor. I'm thinking that good seals at all of the joints and blast gates and 2 hp rather than 1 1/2 has helped. It's about a 20' - 22' run of straight 4" plastic from the lathe to the DC,with two elbows and none of the flex hose.
