Drill bit extensions
Jack Dolan
>I purchased a drill bit extension from local Hdw. to use on the inside of my bowl turnings. For some reason it bent. I think it is not of good quality. The brand was Vermont American. Is there a vendor for higher quality extensions? Thanks
Re: Drill bit extensions
TDaniel
>You might try Irvin; also try a shorter one if possible. The long ones really whip if turned too fast.
TD
Leo Van Der Loo
Re: Drill bit extensions *LINK*
Leo Van Der Loo
>Hi Jack
What are you using the extension for, if you are using it to hold a hollowing tool I would suggest you get something else, the drill bit extensions are only good for that, making a longer drill.
Vermond makes good quality drills etc. maybe not the best but U have to use the tool for the job, I have a couple of those extensions and they do the extending job just fine, and yes I do keep the RPM's at the normal level.
Have fun and take care
Leo V
http://homepage.mac.com/l.vanderloo/PhotoAlbum18.html
