200+ woodworking book reviews
Alcohol and Alcohol
Alcohol and Alcohol
Alcohol and Alcohol
Stan Campbell
>All this talk about availability of Denatured Alcohol got me to wondering if you could mix Denatured Alcohol and Isopropyl Alcohol. Since Isopropyl Alcohol is cheap I thought if you could mix the 2 it might stretch the Denatured Alcohol and that the Denatured Alcohol 'might' remove some or most of the water from the Isopropyl Alcohol or at least cut down on the percentage of water by mixing the 2 Alcohols.
And if anyone is Interested in the MATERIAL SAFETY DATA SHEET:
http://www.syndel.com/msds/denatured_ethanol_msds.
html
Stan
Columbus,OH
I wish everyone a Safe and Happy Holiday.
Re: Alcohol and Alcohol
Denatured Alcohol vs. Isopropanol
Stan Campbell
>I found this on the web, but it doesn't say anything about what will happen if you mix the 2.
Denatured Alcohol is ethyl alcohol, or ethanol, containing traces of benzene. While ethenol, in it's natural form, is a source of combustible fuel, it contains trace amounts of water making it less efficient for burning than in it's denatured form. Introducing Benzene during the distillation process drives out the water contained in ethanol creating a very pure and potent fuel source - denatured alcohol.
NOTE: Ethanol is the alcohol consumed in alcoholic beverages. However, once denatured, ethanol becomes toxic and can cause blindness or death if consumed.
Rubbing Alcohol is isopropanol. It has a completely different molecular structure than ethanol and often contains up to 30% water. Though it is flamible it is a poor choice for fuel.
Stan
Columbus,OH
JL work
>Denatured alcohol typically does not contain benzene as a matter of course. It typically contains Methyl Isobutyl Ketone, Methanol and sometimes Ethyl Acetate and a trace of kerosene. They used to use benzene to "break" the azeotrope so the ethanol would distill over without the water. They stopped using it a while ago due to the environmental concerns.
You can get isopropanol in better grades than the rubbing alcohol grades. Isopropanol will mix thoroughly with ethanol.
Jesper, Denmark
We get highly technical here......
Jesper, Denmark
>I am assuming we are talking about using alcohol to soak bowls prior to drying.
The function of the alcohol is most likely that it dilutes the water in the wood, and when it evaporates, the azeotrope formed between the water and the alcohol means that the evaporation happens in a fixed ratio between the water and the alcohol. This function means that there is more water evaporating than alcohol as the water ratio in the vapor space is fixed by the azeotrope formed.
Assuming this is the right function, it does not matter much which type of alcohol is used (except methanol, as it does not azeotrope,) as they all azeotrope with water and have more water in the vapor form than you would expect from their boiling points or their relative composition in the liquid phase in the wood.
Soaking the wood in the alcohol will most likely make the water/alcohol mixture in the wood equilibrate, so that the mixture is the same in the liquid surrounding the wood and the liquid in the wood itself. as you remove the wood from the bath, the evaporation will favor the water, hence drying will be faster.
I have no clue why the wood would not crack as a result of this, but the drying ( = removal of water) function makes sense.
Happy Thanksgiving
