Re: jet mini or HF34706
Mike-in-Michigan(Richland that is)
>The HF Lathe is a decent lathe, it's basically a Jet 1236 painted green. If you have a local HF store, watch the adds. Before Xmas I bet it will go on sale for 169$ or so.. great deal. I turned a lot of items on that same lathe and I sold it to a HS kid a couple years ago and he's turning things on it. I've never broken a tool rest, but others have. It's a known problem with the Jet 1236's too. I turned bowls up to 10" or so, outboard turned a couple of 11-12" platter's as well a end-grain hollow turnings. It's bit down on power but no more than any lathe that size.
I now have a Jet VS mini and I have to say over all I like as more than the HF but I don't turn any items much over 6-8" anymore. I turn mostly pens, spindle stuff, small lidded boxes, candle holders, wine stoppers, etc... and it excels at that.
Basically it depends on what you want to turn. If you are going to do a lot of small stuff then even though I like the HF, I would go with the Jet. It's portable too!! Then when you are ready for the big stuff -- buy a bigger lathe and keep the jet for small stuff, though you can always turn small stuff on a big lathe, just not the other way around. But if you upgrade to a bigger lathe, the HF might take up to much floor space. Lastly if you buy the belt speed changing Jet, it's only a 20-30$ difference, but the VS speed jet is about 100-120$ more.. that might make the difference. You will be able to turn with any of them.
