What does this look like? *LINK*
Andrew Hilton
>At the link listed below, what does it look like to you?
To me, it looks like a bowl that Remi is forming an off-center recessed foot into. If that is the case, how is he doing it do you think?
I'm supposing he has a cone of wood left inside the bowl that, before taking the foot off the bowl, he off-centered the bowl and formed a tenon to grab hold of with the chuck. Now he's making the recessed foot. Assuming the above is correct, how's he going to get rid of the cone/tenon? Reverse it and put the bottom of the bowl in a vacuum chuck?
OR, maybe he's just using a vacuum chuck on the inside and no cone/tenon and just set it off-center intentionally?
Any other ideas?
I like the idea of an offcenter foot to an otherwise normal bowl form. It'd make a nice presentation piece so that you could see inside the bowl without being directly on top of it looking down.
Offcenter Bowl Bottom?
Re: What does this look like? *LINK*
Jim Pugh in Elyria, OH
>Hi Andrew,
My first impression is that he has it mounted on a vacuum chuck which would permit a person to orient the bowl "out of square" to any extent that would allow the vacuum to still seal.
On the other hand, he seems to be taking a pretty good cut which might be a bit much for most vacuum seals......
So, your question and the picture gives me the idea of perhaps turning a bowl with a round bottom (turning off the spigot), then repositioning it using the vacuum chuck to put the foot noticeably off center.
Perhaps he borrowed a chuck from..
Bob Hackett
>Jean-Francois Escoulen.They know each other and had demos going at the same places,it`d be a logical jump to think they`re sharing techniques.
I believe the Escoulen chuck allows a bowl sized faceplate to be used.
Mainely,Bob
