My New "Mini" Lathe
My New "Mini" Lathe
My New "Mini" Lathe
Bill Grumbine, Kutztown PA
Well, it's not new, and it is only technically a Mini - Mini Max that is. Some of you may remember about two months or so ago, I posted to say that I was selling myself out to the duplicating lathe, and buying a Mini Max T-124 copy lathe in order to do a job that is coming up for a furniture company down the road from me. Well, things got very interesting, and to make a long story a little shorter, my representative from Mini Max was mistaken about the actual location of the lathe. He told me it was on the truck with my CU-300 Smart, when it was actually ON THE BOAT between here and Italy.
His twisting of my arm resulted in my twisting my customer's arm to make a decision, and left me in a very bad spot - an expectant customer and no lathe to do his work. The sun came out eventually though. Just before I discovered this problem, a used T-124 went up for sale in Wildwood NJ. It is 10 years old, used twice according to the customer, and it looks it. Except for some surface rust on a very few spots from lack of use, it looks pretty much like it is right out of the showroom. I am not wild about the Soviet green paint scheme, but I saved enough money that I can get used to that. This machine is virtually identical to the ones being made today, but I got it for a whole lot less. The people at Mini Max took very good care of me in helping me to get hold of this lathe.
Here is an overall shot of the thing. It has a stepped pulley drive with speeds between 600 and some up to 3000. It has a 16" swing, and two knives, a roughing knife that cuts the blank round to fit into the traveling steady, and a finishing knife that follows the template which is fastened onto a bar on the front of the lathe. One of the first things I am going to have to do after I figure out where it is going is to raise it up about six inches. Otherwise I will be running around like the Hunchback of Notre Dame.
Oh yeah, thanks to a lot of you, this place is a sweat shop right now. SWMBO has smoke coming out of the computer she has put so many orders into it, and we are just getting to the point where we can start stuffing envelopes!
Thanks!
Bill
Re: My New "Mini" Lathe
RevDoug
>Great looking piece of machinery, Bill.
I'm really looking forward to getting my copy of the DVD. Ordered it a couple of days ago.
Have fun with the new toy.
Turn 'em round,
RevDoug
Bert Smith
>You will like this lathe Bill. I use one that belongs to a furniture maker and friend of mine to do all of his turned work.
One thing I did to all of of my patterns was to mark the high spot of each bead and any other place on the pattern that widens out. You want to start your cut on the high or thick part and cut into the low or thin part. Never, ever try a climbing cut with this lathe. The spring is too strong to let the cutter follow an uphill cut.
Make sure you have plenty of room to put all of those beautiful patterns you will make also. You will end up with a bunch!
You probably already know these few pointers, but this lathe will take a little practice.
You will definitely stay busy once word gets out!
Bert
>Hi guys
Doug, if you are the Doug in IN, then it is on the way!
Bert, thanks for the comments on the lathe. It is always good to hear from somone who is using one. I know what you mean about that spring! It is a big one! Do you have the new profile cutter or are you using the old one? Also, what are you using for your templates? I am thinking maybe plexiglass for some, and if I get into any that are used very heavily, there is a guy up the road who can cut stainless steel to just about any shape.
Thanks.
Bill
no, KY, no rush
RevDoug
Bert Smith
>I actually turn all of my templates out of glued up 3/4" beech lumber. All of my legs, bedposts finials and such come from books that customers bring in, and pictures or drawings that my friend does.
Whatever you use for a template, it must be very rigid. That spring will really put a lot of pressure on the index pin. If you are copying something long and relatively thin, make sure to place a wooden shim between the template and the bar underneath.
I'm sure I have the older cutter, but another little trick I do is to mount the cutter in the holder upside - down for easier sharpening with a diamond file. It's quick and holds the cutter at a good angle.
I may have some pictures somewhere on my computer... I'll try to find them.
Bert
