pen turning question
Bryan Stone
>Hi everyone, I have turned my first pen with my father, Mark Stone, and we had a lot of trouble along the way. I was wondering if anyone knows the length measurements of the top and bottom barrel for a slim-line kit. One problem along the way was that the pen machanism was pushed in too far and became stuck. It couldn't twist anymore. I'll post a picture of my first and only pen as soon as I get the picture onto the computer. Any help would be greatly appreciated for this newby turner.
Bryan Stone
Re: pen turning question
Bryan Stone
>This is the first and so far only pen I have made. It just got finished tonight, please forward your thoughts. Thanks
Bryan in Chalfont
Stuart Johnson
>Bryon, A small 1/8" brass rod can be used to knock the tip out. It will feed through the center of the twist mech. After it has been removed use a 1/4 bolt and drive the twist mech. back out. I place it in an old block without a tube and just tap it back out either what I think will be sufficient or all the way out. When installing a sneak up on the final depth by inserting about what I think is needed and then use the refill to check to see if it advances as far as I want. I never rely on the markings on the twist mechanisam. They vary somewhat by brand plus I might have removed a bit of the tube when I squared up the blank. To answer your question the tubes are just a tad over 2" maybe 51mm.
Don Evans
>Bryon:
What are you using to press your pen parts together with?
If you can, take a piece of wood (pen blank will work well) and cut it 3 15/16" long.
What you do then is use it to block the press so it cannot press more than that distance. If using a hand clamp, lay the block on the table and lay the clamp on table, keep the block inside the jaws and the pen and press the twist into it. The block of wood will keep it from going too far into the pen.
Now that I've said that, let me add that you should first fold a piece of paper over so it is 4 layers thick and keep that at one end of the block also. After pressing first time, insert the ink cartridge and twist to see if it protrudes far enough out the end of the pen. If not, take out the ink cartridge and remove a couple layers of paper and press again, then test and so forth.
This is what Stuart referred to when he said to "sneak up on it".
In making the block you can get it more accurate by cutting slightly long 1/16" or so and sand it down to right lenght with course sandpaper.
You are not the first to make the mistake you did by many, many beginning pen makers so don't let it bother you. Nice first pen.
There is a penturners group on YAHOO and they make some really great pen's. See if you can find them, I don't have the exact address.
Don
Re: thanks everyone
Bryan Stone
>Wow, thankyou all for the great responses. My dad and I have ordered more penmaking kits and they should arrive in about a week. With this new information I've recieved I hope to produce another pen with much less difficulty then the first. When I finish it I'll post any other questions I have. Thankyou all very much.
Bryan Stone
Jack Stevenson
>Howdy,
I turn out a lot pens. I ruined one when I tried to poke the mechanism back out.
What I do now is take some drill rod of the proper diameter to knock out the nib, then take a fatter piece to tap out the mechanism. Then I put the nib back in and then the mechanism to the proper depth.
Are you involved with the Freedom Pens.org project? If not you might consider getting involved...
Jack
